GPIB device support which is implemented by starting the John Winan's
template
has the statements:
static struct devGpibParmBlock devSupParams;
static struct devGpibParmBlock devSupParams = {
Note that this is legal ISO C but is not legal C++
Josh Stein (APS/ASD) could not make GPIB work with beta12.
We discovered that the above does not work on beta12 but does work on
beta11.
Below is proof that it is a compiler bug.
Question: Has anyone else seen this bug?
If so do you know a solution?
Will a later version of GNU C fix the problem?
Comment:
If devSupParams is made external it works.
Proof of compiler bug.
The following test was run.
#include <stdio.h>
struct test {
int x;
int y;
static struct test mystruct;
static struct test mystruct = {1,2};
int myTest()
printf("mystruct %d %d\n",mystruct.x,mystruct.y);
return(0);
On VxWorks version 5.3.1 the result is:
mystruct 0 0
On VxWorks version 5.2 the result is
mystruct 1 2
On VxWorks version 5.3.1 the compiler output is:
#NO_APP
gcc2_compiled.:
___gnu_compiled_c:
.long 1
.long 2
.text
LC0:
.ascii "mystruct %d %d\12\0"
.even
.globl _myTest
_myTest:
pea a6@
movel sp,a6
lea _statics+4,a0
movel a0@,sp@-
movel a0@(-4),sp@-
pea LC0
jbsr _printf
clrl d0
unlk a6
rts
.data
.even
_statics:
.skip 8
VxWorks version 5.2 generated.
#NO_APP
gcc2_compiled.:
.data
.even
_mystruct:
.long 1
.long 2
.text
LC0:
.even
.globl _myTest
_myTest:
link a6,#0
movel _mystruct+4,sp@-
movel _mystruct,sp@-
pea LC0
jbsr _printf
clrl d0
unlk a6
rts
Marty Kraimer
- Re: beta12 & GPIB & Compiler Bug Benjamin Franksen
Re: MBBI & mask Marty Kraimer
RE: Limits problems in MEDM and the Histogram Record Ken Evans
<1998>
<1998>
