g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Limits problems in MEDM
To: tech-talk@aps.anl.gov
Date: Mon, 21 Sep 1998 13:26:38 -0400
Hello,
I am currently trying to use the histogram record and display data
from it through MEDM. The problem I am encountering is this:
Objects in MEDM such as Strip Chart and Caretesian Plot take their axis
limits from
the LOPR and HOPR fields from the respective process variable. The histogram
record
does not have LOPR and HOPR fields but instead has LLIM and ULIM fields to set
the limits on signal values. MEDM does not look for these fields and
therefore will
not set the axis limits according to the process variable. Is there any way
around
this problem? Has anyone else experienced a similar problem?
Thank you in advance.
Mark J. Ryan
mjryan@mit.edu
Bates Linear Accelerator Center
Prev: RE: Problem building medm2_3_4a on Linux Hammonds, John
Next: device driver for KSC 2917 Kate Feng
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: Problem building medm2_3_4a on Linux Burkhard W. Kolb
Next: RE: Limits problems in MEDM Ken Evans
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
