g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: RE: New 167
To: "'Garrett D. Rinehart'" <rinehart@aps.anl.gov>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 20 Jul 1998 14:11:27 -0600
On Monday, July 20, 1998 1:57 PM, Garrett D. Rinehart [SMTP:rinehart@aps.anl.gov] wrote:
> I just pulled my brand new MVME167 from its box, plugged in the
> ROMs which had been in a known-good CPU and plugged it into my test
> ioc. It echos the boot params and tells me it's attaching
> interfaces, as usual. Then it says "Loading..." for several minutes
> and eventually fails. The known-good CPU continues to work fine
> (when I swapped everything back). Is there something with the ROM
> version that won't work on this new CPU, is the CPU bad, or am I
> just missing something (as usual)?
> Thanks for the help.
> -- Garrett Rinehart
>    IPNS, ANL
Perhaps you need to purge the "arp" cache on the boot host
when changing the Ethernet address which corresponds to a particular
IP address. Type "man arp" for the details.
Jeff
RE: New 167 Bill Brown
Prev: Re: New 167 Garrett D. Rinehart
Next: RE: New 167 Bill Brown
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
