I'm attempting to compile the latest version of EPICS and I'm
running into problems compiling gdd -- which uses the sgi C++
(IRIX 6.2 ) compiler.
The problem is:
gmake[1]: Entering directory
`/projects/711/online_1/epics/v3_13b11/base/src/gdd/O.sgi'
CC +p +w -O -DSGI -I. -I.. -I../../../include -I../../../include
-I../../../include/os/sgi -DUNIX -c ../genApps.cc
"../aitTypes.h", line 83: error(3337): invalid redeclaration of type name
"timespec" (declared at line 11 of "/usr/include/sys/ptimers.h")
struct timespec
1 error detected in the compilation of "../genApps.cc".
gmake[1]: *** [genApps.o] Error 1
gmake[1]: Leaving directory
gmake: *** [install.sgi] Error 2
Which I have determined is due to the fact that _POSIX_C_SOURCE is < 3 for
the sgi os, and struct timespec is defined elsewhere: in sys/ptimers.h
aitTypes.h:
#ifndef vxWorks
#if (_POSIX_C_SOURCE < 3) && !defined(solaris) && !defined(SOLARIS)
struct timespec
time_t tv_sec;
long tv_nsec;
typedef struct timespec timespec;
#endif
#endif
I have fixed the problem by additing two additional conditionals:
aitTypes.h:
#ifndef vxWorks
#if (_POSIX_C_SOURCE < 3) && !defined(solaris) && !defined(SOLARIS) &&
!defined(sgi) && !defined(SGI)
struct timespec
time_t tv_sec;
long tv_nsec;
#endif
#endif
I could not find where _POSIX_C_SOURCE is defined in the configure
files. Can someone tell me where I can set this variable so that the
fix can avoid changing the code?
Jeff
_____________________________________________________
Jeffrey McDonald, Florida State jemcdon@fnal.gov
FNAL MS 352 phone 630-840-8301
Batavia, IL 60510 fax 630-840-8886
Re: BITBUS availability... Ned Arnold
compilation of src/ca Jeffrey Mcdonald
<1998>
RE: v3_13Beta11 compilation Error Jeff Hill
<1998>
