g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: RE: CA broadcast problems on Solaris 2.6?
To: "'Dave Barker'" <barker@acrux.ligo.caltech.edu>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 18 Mar 1998 10:35:11 -0700
Dave,
On Tuesday, March 17, 1998 6:03 PM, Dave Barker [SMTP:barker@acrux.ligo.caltech.edu] wrote:
> I'm getting the following problems when running MEDM on my
> solaris 2.6 machines:
> CA.Client.Diagnostic..............................................
>     Message: "No internet interface with broadcast available"
>     Severity: "Warning" Context: "caAdd : ca_build_and_connect failed
>     Source File: ../medmCA.c Line Number: 680
> but when I ifconfig -a, I get:
> lo0: flags=849<UP,LOOPBACK,RUNNING,MULTICAST> mtu 8232
>         inet 127.0.0.1 netmask ff000000
> hme0: flags=863<UP,BROADCAST,NOTRAILERS,RUNNING,MULTICAST> mtu 1500
>         inet 206.61.208.109 netmask ffffff00 broadcast 206.61.208.255
Quick workaround:
Set EPICS_CA_AUTO_ADDR_LIST to NO and specify an explicit broadcast
address in EPICS_CA_ADDR_LIST (see the CA reference manual).
Long term:
The code involved is in base/src/ca/if_depn.c
in routine caDiscoverInterfaces(). One possibility is that the code has to
be recompiled on Solaris 2.6 in order for the interface flags or ioctl codes
to be defined correctly. You might look in the release notes for Solaris 2.6.
You could also build EPICS base with debug (ie HOST_OPT = NO) and then
step through this routine in the debugger to get a closer look at the
situation.
I just spoke with Rozelle here, and it turns out that we recently installed a
Solaris 2.6 machine here. Rozelle said that she will try to reproduce
the problem here.
Jeff
> the broadcast address is set correctly for a Class C network. I have
> seen this problem
> on all types of Solaris 2.6 machines (E2 and Ultra30).
> Can anyone help with this?
> thanks,
> Dave Barker.
> Dave Barker                | Tel    Office: 509 373 6203 (msg service)
> LIGO Hanford Observatory   |        Lab 0:  509 373 3580
> P.O. Box 1970; MS S9-02    |        Lab 1:  509 372 3976
> Richland                   | Fax    509 372 2178
> WA 99352                   | e-mail barker@ligo.caltech.edu
> United States of America   | S/W Engineer, UNIX Sys Admin.
Prev: CA broadcast problems on Solaris 2.6? Dave Barker
Next: RE: CA broadcast problems on Solaris 2.6? Rozelle Wright
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
