g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: EPICs on PC
To: Kay-Uwe.Kasemir@Physik.Uni-Osnabrueck.DE (Kay-Uwe Kasemir)
Cc: tech-talk@aps.anl.gov
Date: Thu, 02 Oct 1997 10:12:13 +0100 (MET)
> Even more:
> People at DESY have tried some version of Tornado/VxWorks
> where VxWorks is not a separate _OS_ for the PC but a _task_
> running unter Windows95,
> so then your PC can be both 'host' and 'IOC' at the same time.
> However, I cannot remember the name of that VxWorks version.
> I think it was not an original Windriver product and you loose
> some real-time specs because VxWorks is just one task
> among other Windows95 task.
VxWorks 5.3 - from LP-elektronik (more details when I came back to DESY)
But The VxWorks is not a task of Win95, a VxWin kernel is ruuning,
(and more or less) it has 2 task, one high priority, the
VxWorks and one low priority , the Win95. You also need a special
card from LP-Elektronik.
You have lost only the system level debuggiing, while in this case
VxWorks 'is' running, and the low priority job (Win95) -including
rthe debbuger tools are waiting for the 'end' of VxWorks.
> Hope this helps,
> -Kay
Gabor Csuka
DESY,Germany
Re: EPICs on PC Kay-Uwe Kasemir
Prev: Re: EPICs on PC Kay-Uwe Kasemir
Next: Re: Generic Record Types Benjamin Franksen
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Next: RE: EPICs on PC Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
