g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: Generic Record Types
To: jemcdon@FNAL.GOV
Cc: tech-talk@aps.anl.gov
Date: Fri, 26 Sep 97 16:13:48 MDT
> From jemcdon@FNAL.GOV Fri Sep 26 15:57:01 1997
> Return-Path: <jemcdon@FNAL.GOV>
> Date: Fri, 26 Sep 1997 16:56:14 -0500 (CDT)
> Subject: Generic Record Types
> To: tech-talk@aps.anl.gov
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > charset=US-ASCII>
> Content-Transfer-Encoding: 7BIT
> Content-Length: 751
> X-Lines: 21
> Hello,
>         There are several generic records that Mark Rivers has written
> for EPICS R3.12 that would be very useful in R3.13.  In particular, the
> generic VME record and the generic GPIB record would be very useful for
> some of my work.
>         Does anyone have a tool for converting .ascii files into
> the required .dbd files or has someone already converted these files into
> the format required to use these generic record types in R3.13?  (It may
> not be as simple as just converting .ascii files into .dbd files.)
>                         Jeff
> _____________________________________________________
> Jeffrey McDonald, Florida State   jemcdon@fnal.gov
> FNAL MS 352			  phone   630-840-8301
> Batavia, IL 60510                 fax     630-840-8886
Look on page 6 and 7 of the EPICS Release BaseR31.3.0.beta11 release notes.
This describes routines starting with sdr* that
exist in the base/bin/<host> directory
for epics 313 releases.  You must however, have a default.dctsdr
file from 312 to do the conversion.  Someone may have done the conversions
already if you list which ones you need.  Also there are tools available
on thoth.atdiv.lanl.gov /epics/BETA_4_DB2CAPSYM.tar.gz
and /epics/DBST_1_0.tar. which can be used to create capfast symbols
and edb.def definitions for capfast respectively. But if someone already
has made the symbols it is easier.
Hope this helps,
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs LANSCE-8  FAX (505) 665-5107      |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : rwright@lanl.gov   |
Prev: Generic Record Types Jeffrey Mcdonald
Next: Re: Generic Record Types Tim Mooney
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: Generic Record Types Benjamin Franksen
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
