jennings@the-brain.bessrc.aps.anl.gov wrote:
> Kurt A. Goetze wrote:
> > Guy Jennings said:
> > > Just ran into a potential gotcha with the ACS SPD-3M Microstepper
> > motor
> > > drive module.=3DA0=3DA0 It is NOT a drop-in replacement for the SPD=
-6U
> > > drive!!!=3DA0=3DA0 The SPD-3M is a bipolar drive and needs differen=
t
> > connections
> > > when used with a 6-wire motor.
> > > Users beware!!!
> > I guess I would like to know more about how your motor is wired
> up.=3DA0
> > My
> > experience is that the SPD3M worked well as a drop-in replacement
> for
> > the
> > unipolar StepPak drive (using a 6 or 8 lead motor).
> > Kurt Goetze
> > APS/XFD/Beamline Controls
> =3DA0 We are using the connections in the APS 'standard' (I think!).
> For the SPD-6U:
> ELCO=3DA0=3DA0=3DA0 Signal=3DA0=3DA0=3DA0 SLO-SYN 6-lead
> A=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1 Out=3DA0=3DA0=3DA0 Red
> B=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 2 Out=3DA0=3DA0=3DA0 Red/White
> C=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3 Out=3DA0=3DA0=3DA0 Green
> D=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 4 Out=3DA0=3DA0=3DA0 Green/White
> E=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1 Ret=3DA0=3DA0=3DA0 Black
> F=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 2 Ret=3DA0=3DA0=3DA0 Black
> H=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3 Ret=3DA0=3DA0=3DA0 White
> J=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 4 Ret=3DA0=3DA0=3DA0 White
> This corresponds with Fig. 4.2 on page 17 of the ACS manual (Jan
> 1997).
> This does not match up with any of the connection diagrams on page 24
> or
> 25 of the
> ACS manual.
> I was able to succesfully move the motor with the following
> connections:
> A=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1+=3DA0=3DA0=3DA0 Red
> B=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> C=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3+=3DA0=3DA0=3DA0 Green/White
> D=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> E=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1-=3DA0=3DA0=3DA0 Red/White
> F=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> H=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3-=3DA0=3DA0=3DA0 Green
> J=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> This corresponds with Fig. 5.2 on page 25 of the ACS manual.
> Interestingly enough, we had previously tried the microstepper drives
> with an
> 8-lead motor and found no problems.
=A0 Sorry about the =3DA0 junk - something to do with Netscape...
The connection lists should be:
For the SPD-6U:
ELCO=A0=A0=A0 Signal=A0=A0=A0=A0 SLO-SYN 6-lead
A=A0=A0=A0=A0=A0=A0 Ph 1 Out=A0=A0 Red
B=A0=A0=A0=A0=A0=A0 Ph 2 Out=A0=A0 Red/White
C=A0=A0=A0=A0=A0=A0 Ph 3 Out=A0=A0 Green
D=A0=A0=A0=A0=A0=A0 Ph 4 Out=A0=A0 Green/White
E=A0=A0=A0=A0=A0=A0 Ph 1 Ret=A0=A0 Black
F=A0=A0=A0=A0=A0=A0 Ph 2 Ret=A0=A0 Black
H=A0=A0=A0=A0=A0=A0 Ph 3 Ret=A0=A0 White
J=A0=A0=A0=A0=A0=A0 Ph 4 Ret=A0=A0 White
For the SPD-3M
ELCO=A0=A0=A0 Signal=A0=A0=A0=A0 SLO-SYN 6-Lead
A=A0=A0=A0=A0=A0=A0 Ph 1+=A0=A0=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
C=A0=A0=A0=A0=A0=A0 Ph 3+=A0=A0=A0=A0=A0 Green/White
D=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
E=A0=A0=A0=A0=A0=A0 Ph 1-=A0=A0=A0=A0=A0 Red/White
F=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
H=A0=A0=A0=A0=A0=A0 Ph 3-=A0=A0=A0=A0=A0 Green
J=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
--- Begin Message ---
> motor
> > drive module.=A0=A0 It is NOT a drop-in replacement for the SPD-6U
> > drive!!!=A0=A0 The SPD-3M is a bipolar drive and needs different
> connections
> > Users beware!!!
> I guess I would like to know more about how your motor is wired up.=A0
> My
> experience is that the SPD3M worked well as a drop-in replacement for
> the
> Kurt Goetze
=A0 We are using the connections in the APS 'standard' (I think!).
For the SPD-6U:
ELCO=A0=A0=A0 Signal=A0=A0=A0 SLO-SYN 6-lead
A=A0=A0=A0=A0=A0=A0 Ph 1 Out=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0 Ph 2 Out=A0=A0=A0 Red/White
C=A0=A0=A0=A0=A0=A0 Ph 3 Out=A0=A0=A0 Green
D=A0=A0=A0=A0=A0=A0 Ph 4 Out=A0=A0=A0 Green/White
E=A0=A0=A0=A0=A0=A0 Ph 1 Ret=A0=A0=A0 Black
F=A0=A0=A0=A0=A0=A0 Ph 2 Ret=A0=A0=A0 Black
H=A0=A0=A0=A0=A0=A0 Ph 3 Ret=A0=A0=A0 White
J=A0=A0=A0=A0=A0=A0 Ph 4 Ret=A0=A0=A0 White
This corresponds with Fig. 4.2 on page 17 of the ACS manual (Jan 1997).
This does not match up with any of the connection diagrams on page 24 or
25 of the
ACS manual.
I was able to succesfully move the motor with the following connections:
A=A0=A0=A0=A0=A0=A0=A0 Ph 1+=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
C=A0=A0=A0=A0=A0=A0=A0 Ph 3+=A0=A0=A0 Green/White
D=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
E=A0=A0=A0=A0=A0=A0=A0 Ph 1-=A0=A0=A0 Red/White
F=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
H=A0=A0=A0=A0=A0=A0=A0 Ph 3-=A0=A0=A0 Green
J=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
with an
--- End Message ---
Re: ACS Microstepper Drives jennings
Re: ACS Microstepper Drives Kurt A. Goetze
<1997>
Re: ACS Microstepper Drives Pete Jemian
[no subject] Guy Jennings
<1997>
