g+
g+ Communities
Argonne National Laboratory
1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: RAWL/RAWH
To: tech-talk@aps.anl.gov
Date: Fri, 08 Nov 1996 14:24:07 -0600
It has been several weeks since a message has been sent about
adding RAWL, RAWH to the ai and ao records. Thus I am assuming
that everyone who had a strong opinion has responded.
This message attempts to summarize the responses.
The majority of the responses did not think it is a good
idea to add these fields. Perhaps the best reason is that
given by an Application Developer. The response was:
    Q. What am I supposed to put in the RAWH and RAWL fields ?
    A. You might not have to put anything in there, but then again, you might.
    Q. How do I know ?
    A. It depends on the device type you are using.
    Q. My device type is thisDeviceHere. Do I need to worry about it ?
    A. You have to ask the author of the device support.
    Q. Who's that ?
    A. < no answer >
Several other negative responses were given by device/driver developer's.
The comments indicated that RAW/RAWH are only sometimes a problem and,
in any case, a small subset of the problems. Thus adding these fields
will not be much help. A couple of responses indicated that for particular
cases they are a big help.
Several device/driver developers stated that they used the parm field
(often with INST_IO which has only a parm field) to solve their problem.
The responses also showed that the parm field needed a lot of syntax
associated with it in order to solve the problem.
Several responses stated that we need a hardware configuration tool.
This is something we have realized for a long time but have never been
able to get a consensus on what it should be or do.
As a result of the RAWL/RAWH discussion I also got a message from Ralph Lange
that gave some ideas he and several other people at BESSY came up with when
they discussed the hardware configuration problem.
This lead to several E-mail messages between them, a few LANL developers,
and a few APS developers.  Maybe this may lead to something.
I will send the last E-mail I sent on to them. No one responded
to it so that means that either everyone was getting tired or else
there was no basic disagreement.
Marty Kraimer
Prev: Using g++ with 3.13 beta2 Nick Rees
Next: Hardware Configuration Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: Using g++ with 3.13 beta2 Kazuro FURUKAWA
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
