>Q: Why does this happen?
>In file CONFIG_SITE, I set
>CROSS_COMPILER_TARGET_ARCHS=mv162
>since the only crate processor I have is a mv162.
>Then I rebuilt EPICS R3.12.2 base.
>Here's the output from when the crate boots.
>-----------------------------% clip here %-----------------------------
>ld < targetmv162/iocCore
>undefined symbol: ___eqdf2
>undefined symbol: ___gtdf2
This is because you have 'soft-float' defined somewhere and are not loading
the floating point emulation libraries that come with vxWorks. I don't
know *how* you are supposed to load them... I don't use that stuff, but
I suspect that if you build vxWorks for soft-float, they are built in.
I also suspect that you have a board with floating point on it... are loading
the vxWorks w/o soft-float (as you should for that board) and are just building
EPICS wrong (for a soft-float environment.)
>Q: Do I need to compile for BOTH the mv162 AND the mv167?
>That is,
>CONFIG_SITE: CROSS_COMPILER_TARGET_ARCHS=mv162 mv167
Not that I am aware of.
>Q: Is this a bug?
Nope. It is a feature ;-)
--John Winans
Re: mv162 only Paul Banta
fwd: a note from hurikon about performance John R. Winans
<1996>
Re: mv162 only Rozelle Wright
<1996>
