g+
g+ Communities
Argonne National Laboratory
<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: CA library on the PC
From: mark@bessrc.msd.anl.gov (Mark S. Engbretson (Bessrc-Cat))
Date: Mon, 5 Dec 94 11:52:18 CST
Jeff Said
>Initial port was done at LBL by Chris Timossi. I integrated the
>his changes + improved the general portability of the code for 3.12.
>This is in the latest 3.12 beta however the PC port needs to be
>retested.  Chris: are you still interested in testing the port?
>Perhaps Mike can fetch you a copy?
I have looked at the code a bit over the weekend . . . by any chance, could
you locate a makefile for the Windows build and make it available?
The compilers which I have access to are having some problems with the code
and I assume that most of this is probably due to defines wrongly defined,
assumptions that I am assuming wrongly, code that I am attempting to build
which should not be part of the windows CA library, or maybe even the chance
that I will have to change compilers.
Me
Prev: Re: CA library on the PC Jeff Hill
Next: pvget to an _output_ record Bill Brown
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
