g+
g+ Communities
Argonne National Laboratory
<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Motorola 162 Flash Memory Problem
Date: Mon, 3 Oct 94 07:15:40 MDT
2. MVME162LX Flash Memory Corruption
   A design problem has been discovered by the field which can cause
   flash memory to be corrupted after a power cycle.  Apparently Intel has
   redefined the powerdown pin of their flash chip to be "powerdown/
   /reset".
   The MCG fix involves connecting the powerup reset (PURESET* / pin 12 on U5)
   line to pin 12 of the flash chip (U43).
   This problem exists in the following part numbers: MVME162-223,200,
   263,283,233,253,270,271,272,273,280,281,282,210,211,212,213,215,220,
   221,222,260,261,and 262.
   NOTE: This will be covered under warranty repair.  Customers implement-
	 ing this fix themselves will void their warranty.
Prev: Re: Communication between IOCs ... Marty Kraimer
Next: sparc processors in IOCs William Lupton
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: IBM RS 6000's Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
