g+
g+ Communities
Argonne National Laboratory
<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: CAMAC drivers
From: "Eric Bjorklund, NPSM" <BJO@accr.lampf.lanl.gov>
Date: Thu, 25 Aug 1994 14:39:56 -0600 (MDT)
At LANL we are currently working on an extension of the CEBAF serial highway
driver (adding support for LAMs and multiple branches per IOC).  This driver is
an implementation of the ESONE standard CAMAC library and is designed in two
sections.  The ESONE interface is in one module and the hardware interface is
in a separate module.  The idea is that your device support routines can use
the ESONE interface independantly of which hardware driver you load.
We are currently using the Hytec 2992 serial driver (as is CEBAF and Duke).
The design should allow you to support parallel drivers as well (like the 3992)
by writing a different hardware support module.
Further information can be obtained from:
		bjorklund@lanl.gov
Prev: CAMAC driver Steve Lewis
Next: Re: CAMAC driver watson
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: CAMAC driver watson
Next: getResources Marty Kraimer
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
