g+
g+ Communities
Argonne National Laboratory
<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: symbol tables and incremental run time loading
Date: Tue, 21 Jun 94 09:16:29 -0500
>	Does LYNX have a linking loader and command line access to the
>global symbol table? Is it possible to invoke subroutines directly?
>Is it possible to resolve strings to memory locations through subroutine
>calls?
It would be a mistake to *require* an incremental run time loading
option with a global name space from an OS before considering an EPICS
port to it... yah it would make things easier, but it would only serve
as a reason to procrastinate on the real issue.  Like doing a posix
port to something like Solaris.
We do not need an incremental loader even today.  So why require one.
The name space issue should be solved by rethinking the init process.
(No, I don't have any ideas at the moment, but probably will as the
SDR situation is reviewed for R4.  The worst case solution would be
for us to implement our own -- similar to the way vxWorks builds the
one for their boot image perhaps.)
--John
Prev: Re: vxWorks Carl W. Cork
Next: Re: symbol tables and incremental run time loading Bob Dalesio
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: CA problem from Vax Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
