This Message Is From an External Sender
This message came from outside your organization.
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/pull/463__;!!G_uCfscf7eWS!Zn6wAiXcGXOFffznkTQ8saPYuWsW6uQDQWE3zlHrxqzOLC87YVlUiwDvAz2xB1BzTy0fNk_2ePVlzvybRiho6vFLJwpC$ -- You received this bug notification because you are a member of EPICS Core Developers, which is subscribed to EPICS Base. Matching subscriptions: epics-core-list-subscription https://urldefense.us/v3/__https://bugs.launchpad.net/bugs/2052814__;!!G_uCfscf7eWS!Zn6wAiXcGXOFffznkTQ8saPYuWsW6uQDQWE3zlHrxqzOLC87YVlUiwDvAz2xB1BzTy0fNk_2ePVlzvybRiho6hvnEaYf$ Title: dbLoadRecords with subs=NULL fails to expand macros with defaults Status in EPICS Base: Confirmed Bug description: A template file that only contains macros with default values can be loaded with `dbLoadRecords("file.db","")` but not with `dbLoadRecords("file.db",NULL)`. In particular, in the startup script, it cannot be loaded with `dbLoadRecords "file.db"` but only with `dbLoadRecords "file.db",""`. (VxWorks shell as well as iocsh.) Using such a macro in a record name results in the error message: ERROR: Bad character '$' in Record/Alias name "$(P=)Name" Using macros with defaults in fields shows error messages like this: ERRORName.PREC Has unexpanded macro Can't set "Name.PREC" to "$(PREC=3)" : Bad Field value ERRORERROR failed to load 'file.db' (Unrelated: Someone please fix the missing blanks after ERROR and the ERRORERROR.) The reason is that `dbReadCOM`, the function that does the real work, only creates a `macHandle` when `substitutions` is not `NULL`. Not having a `macHandle` prevents any macro substitution from working, even those which provide a default value. In the old times, when macros could not have defaults, this was fine, but not any more. A macro handle should always be created, even if it stays empty when `substitutions` is `NULL`. To manage notifications about this bug go to: https://urldefense.us/v3/__https://bugs.launchpad.net/epics-base/*bug/2052814/*subscriptions__;Kys!!G_uCfscf7eWS!Zn6wAiXcGXOFffznkTQ8saPYuWsW6uQDQWE3zlHrxqzOLC87YVlUiwDvAz2xB1BzTy0fNk_2ePVlzvybRiho6tnykGku$
ANJ, 19 Feb 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
