During an upgrade of our build system, I encountered this error:
*** buffer overflow detected ***: terminated
[1] 2022546 IOT instruction (core dumped) ./result/bin/softIoc
-S -d nixos/tests/archiver-appliance/test.db
After a bit of debugging, I found that _FORTIFY_SOURCE=3 was enabled by
default, which caused extra checks to be done in `strcpy`, which failed
in this particular instance:
1. running `softIoc -S -d test.db` (see attachments for the .db file)
2. EPICS reads the calcExample record
3. EPICS calls dbAllocRecord
4. EPICS initialize the CALC field
5. EPICS copies the initial value of CALC `"0"` to the alloc'ed record
6. crash because overflow detected
See the backtrace in the attachments.
This is weird because the CALC value is a char[80], so there shouldn't
be any overflow.
Can anyone reproduce? Can anyone see why this crashes?
In the meantime, I'll just fall back to _FORTIFY_SOURCE=2
Thanks a lot, and have a great day.
Rémi NICOLE <remi.nicole at cea.fr>
CEA/DRF/IRFU/DIS/LDISC
# Adapted from: https://github.com/epics-base/epics-base/blob/524f81b8bd147bb714c9ea7b7462b8912a134246/modules/database/src/template/top/exampleApp/Db/dbExample1.db
# To test regularly changing records
record(ai, "aiExample")
field(DESC, "Analog input")
field(INP, "calcExample.VAL NPP NMS")
field(EGUF, "10")
field(EGU, "Counts")
field(HOPR, "10")
field(LOPR, "0")
field(HIHI, "8")
field(HIGH, "6")
field(LOW, "4")
field(LOLO, "2")
field(HHSV, "MAJOR")
field(HSV, "MINOR")
field(LSV, "MINOR")
field(LLSV, "MAJOR")
record(calc, "calcExample") {
field(DESC, "Counter")
field(SCAN, "1 second")
field(FLNK, "aiExample")
field(CALC, "(A<B)?(A+C):D")
field(INPA, "calcExample.VAL NPP NMS")
field(INPB, "9")
field(INPC, "1")
field(INPD, "0")
field(HOPR, "10")
field(HIHI, "8")
field(HIGH, "6")
field(LOW, "4")
field(LOLO, "2")
field(HSV, "MINOR")
field(LSV, "MINOR")
# To test "static" records
record(ai, "static") {
field(VAL, "1")
# To test the ADEL field
record(ai, "staticDeadband") {
field(VAL, 0)
field(ADEL, 5)
# To test "static", but regularly processed records
record(ai, "staticProcessed") {
field(VAL, 0)
field(ADEL, -1)
# To test waveforms
record(waveform, "waveform") {
field(NELM, 10)
#0 0x00007ffff78a4d7c in __pthread_kill_implementation () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#1 0x00007ffff78559c6 in raise () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#2 0x00007ffff783e8fa in abort () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#3 0x00007ffff783f767 in __libc_message.cold () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#4 0x00007ffff79337f9 in __fortify_fail () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#5 0x00007ffff79331b4 in __chk_fail () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#6 0x00007ffff7f40b91 in strcpy (__src=0x45f770 "0", __dest=0x4d1be8 "")
at /nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-glibc-2.38-27-dev/include/bits/string_fortified.h:79
#7 dbAllocRecord (pdbentry=pdbentry@entry=0x422638, precordName=precordName@entry=0x422578 "calcExample") at ../dbStatic/dbStaticRun.c:125
#8 0x00007ffff7f3635f in dbCreateRecord (pdbentry=pdbentry@entry=0x422638, precordName=precordName@entry=0x422578 "calcExample")
at ../dbStatic/dbStaticLib.c:1441
#9 0x00007ffff7f3b237 in dbRecordHead (recordType=recordType@entry=0x4225d8 "calc", name=name@entry=0x422578 "calcExample", visible=visible@entry=0)
at ../dbStatic/dbLexRoutines.c:1132
#10 0x00007ffff7f3dd14 in dbRecordHead (visible=0, name=0x422578 "calcExample", recordType=0x4225d8 "calc") at ../dbStatic/dbLexRoutines.c:1104
#11 yyparse () at ../dbStatic/dbYacc.y:234
#12 pvt_yy_parse () at ../dbStatic/dbYacc.y:395
#13 dbReadCOM (ppdbbase=ppdbbase@entry=0x7ffff7f77da0 <pdbbase>, filename=filename@entry=0x7fffffffbe5c "nixos/tests/archiver-appliance/test.db",
fp=fp@entry=0x0, path=path@entry=0x0, substitutions=substitutions@entry=0x7fffffffb6c0 "") at ../dbStatic/dbLexRoutines.c:294
#14 0x00007ffff7f3f74d in dbReadDatabase (ppdbbase=ppdbbase@entry=0x7ffff7f77da0 <pdbbase>,
filename=filename@entry=0x7fffffffbe5c "nixos/tests/archiver-appliance/test.db", path=path@entry=0x0, substitutions=substitutions@entry=0x7fffffffb6c0 "")
at ../dbStatic/dbLexRoutines.c:350
#15 0x00007ffff7f0c52d in dbLoadRecords (file=0x7fffffffbe5c "nixos/tests/archiver-appliance/test.db", subs=0x7fffffffb6c0 "") at ../db/dbAccess.c:800
#16 0x0000000000407595 in main (argc=4, argv=0x7fffffffb888)
at /nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-gcc-12.3.0/include/c++/12.3.0/bits/basic_string.h:233
Build failed: epics-base base-win32_static_set_thread_names-55 AppVeyor via Core-talk
Build failed: EPICS Base 7 base-7.0-1096 AppVeyor via Core-talk
<2024>
<2024>
