2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: [Bug 2004463] Re: iocsh on vxWorks broken
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 01 Feb 2023 18:48:53 -0000
> The attached patch ...
Applied as 3dbc9ea26491dc676888fca091e78cddf9a8760c
I've also added a GHA job with -funsigned-char
** Changed in: epics-base
       Status: New => Fix Committed
   Importance: Undecided => Critical
     Assignee: (unassigned) => mdavidsaver (mdavidsaver)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2004463
Title:
Status in EPICS Base:
  Fix Committed
Bug description:
  Since commit 60128ee9 "Com: separate iocsh argument splitting", iocsh
  is broken on VxWorks (tested with version 6.9.4.12)
  Any command prints the error "Unbalanced quote."
  > iocsh
  epics> echo
  Unbalanced quote.
  epics> "echo"
  Unbalanced quote.
  epics> "echo
  Unbalanced quote.
  epics> echo bla
  Unbalanced quote.
  epics> echo 1 2 3
  Unbalanced quote.
  epics> exit
  Unbalanced quote.
  I have started investigating....
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2004463/+subscriptions
[Bug 2004463] [NEW] iocsh on vxWorks broken Dirk Zimoch via Core-talk
Prev: [Bug 2004463] Re: iocsh on vxWorks broken mdavidsaver via Core-talk
Next: Build failed: epics-base base-integration-927 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: [Bug 1903924] Re: The aao record type could use a DOL input link Andrew Johnson via Core-talk
ANJ, 02 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
