2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: [Bug 1956459] [NEW] epicsThreadTest crashes on vxWorks 6.9.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 05 Jan 2022 13:03:35 -0000
Public bug reported:
Since commit 8fdaa13 "errlog: eltc() re-add flush", epicsThreadTest (and
thus epicsRunLibComTests) crashes on vxWorks 6.9.0 (but not on 6.7!) on
my mv5100 PPC IOC:
epicsThreadTest  > logfile
program
Exception current instruction address: 0x00000004
Machine Status Register: 0x0208b032
Condition Register: 0x84000882
trcStack aborted: error in top frame
Unfortunately the stack is so corrupted that it is not tracable.
The faulty address 0x00000004 hints to a dereferenced NULL pointer.
After the test, the logfile contains:
***** epicsThreadTest *****
1..15
# System has 1 CPUs
ok  1 - ncpus > 0
# main() thread 0x51a8c0
not ok  2 - Join delayed parent (0 seconds) # TODO Thread join doesn't work
ok  3 - Join tests #1 completed
not ok  4 - Join delayed parent (0 seconds) # TODO Thread join doesn't work
ok  5 - Join tests #2 completed
ok  6 - pget == pset
ok  7 - thread.getPriority() == epicsThreadGetPriority(self)
ok  8 - pget == pset
ok  9 - thread.getPriority() == epicsThreadGetPriority(self)
ok 10 - pget == pset
ok 11 - thread.getPriority() == epicsThreadGetPriority(self)
not ok 12 - infoB.didSomething
not ok 13 - infoA.didSomething
not ok 14 - threadA epicsThreadIsOkToBlock() = 1280
not ok 15 - threadB epicsThreadIsOkToBlock() = 6279168
It ends just before the test results are printed.
My analysis shows that the crash is most likely related to the fact that
epicsThreadMustJoin() is non-functional on vxWorks 6.9.0 and thus
testOkToBlock() exits before the test threads finish. This takes the
local variables infoA and infoB out of context while the test threads
are still using them. This overwrites local variables (or the call
stack) in the next function eltc().
The solution is to make infoA and infoB static (or global). Or skip the
whole test #ifndef EPICS_THREAD_CAN_JOIN.
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1956459
Title:
Status in EPICS Base:
  New
Bug description:
  (and thus epicsRunLibComTests) crashes on vxWorks 6.9.0 (but not on
  6.7!) on my mv5100 PPC IOC:
  program
  1..15
  # System has 1 CPUs
  ok  1 - ncpus > 0
  ok  6 - pget == pset
  ok  8 - pget == pset
  that epicsThreadMustJoin() is non-functional on vxWorks 6.9.0 and thus
  the whole test #ifndef EPICS_THREAD_CAN_JOIN.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1956459/+subscriptions
Prev: Re: breaktable name incompatibilities Michael Davidsaver via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-454 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
