Hello Heinz,
On 1/18/19 12:54 PM, Heinz P. Junkes via Core-talk wrote:
Unfortunately I have to change something for the new RTEMS when generating the testfiles in /src/tool/makeTestfile.pl.
What is the most elegant way to do this? I can't tell if I'm doing Rtems4 or Rtems5 in the script.
When I just added the arguments -append --console=/dev/com1 to the qemu-system-i386 command line they didn't affect the tests running on RTEMS-4.10.2 at all, so I don't see a problem with just adding that independent of the RTEMS version. I haven't
checked RTEMS-4.9 although I don't see why that would behave differently (but please enlighten me if my assumptions there are wrong).
Does RTEMS-5 really need the double-quotes around its kernel command line? I left them out for my tests but I'm not running RTEMS-5 so I don't know for sure. I would prefer to just use $exe instead of $exec in the die message if it does. Can you try this patch
instead of yours against both RTEMS versions:
diff --git a/src/tools/makeTestfile.pl b/src/tools/makeTestfile.pl
index 7d29876..173f84a 100644
--- a/src/tools/makeTestfile.pl
+++ b/src/tools/makeTestfile.pl
@@ -38,7 +38,10 @@ if( $TA =~ /^win32-x86/ && $HA !~ /^win/ ) {
# Run pc386 test harness w/ QEMU
} elsif( $TA =~ /^RTEMS-pc386-qemu$/ ) {
- $exec = "qemu-system-i386 -m 64 -no-reboot -serial stdio -display none -net nic,model=ne2k_pci -net user,restrict=yes -kernel $exe";
+ my $args = '-m 64 -no-reboot -serial stdio -display none '
+ . '-net nic,model=ne2k_pci -net user,restrict=yes '
+ . '-append --console=/dev/com1'
+ $exec = "qemu-system-i386 $args -kernel $exe";
# Explicitly fail for other RTEMS targets
} elsif( $TA =~ /^RTEMS-/ ) {
@@ -59,7 +62,8 @@ use Cwd 'abs_path';
\$ENV{HARNESS_ACTIVE} = 1 if scalar \@ARGV && shift eq '-tap';
\$ENV{TOP} = abs_path(\$ENV{TOP}) if exists \$ENV{TOP};
-system('$exec') == 0 or die "Can't run $exec: \$!\\n";
+system('$exec') == 0
+ or die "Can't run $exe: \$!\\n";
EOF
close $OUT or die "Can't close $target: $!\n";
- Andrew
- Need changes to makeTesfile.pl for Rtems5 Heinz P. Junkes via Core-talk
Strange change in behavior from 7.0.1 to 7.0.2 Mark Rivers via Core-talk
<2019>
<2019>
ANJ, 23 Jan 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
