Ernest,
You can test int64inRecord with the softIocPVA executable.
> cat <<EOF >test64.db
> record(int64in, "test:i64") {
> field(VAL, "0x7fffffffffffffff")
> EOF
> softIocPVA -d test64.db
then
> pvget test:i64
> test:i64 <undefined> 9223372036854775807
If you do try, please also pull down the latest which includes a
candidate fix.
https://github.com/epics-base/pva2pva/issues/25#issuecomment-452429849
On 1/8/19 7:58 AM, Williams Jr., Ernest L. via Core-talk wrote:
> Hi Timo,
> Response below
> *From:* [email protected] <[email protected]> on behalf of Timo Korhonen via Core-talk <[email protected]>
> *Sent:* Tuesday, January 8, 2019 3:08 AM
> *To:* EPICS Core Talk
> *Subject:* 64-bit records
> Hi all,
> I made a quick try to use the 64-bit record types (int64in/int64out) with base 7.0.2.
> Trying to pvget the record, I get the following message on the IOC console:
> epics> 2019-01-08T11:43:50.309 an exception caught while in receiveThread at ../../src/remote/codec.cpp:1144: Unsupported DBR code
> And pvget times out. With caget, I can read the value but as expected, I do not get the 64-bit integer (because ca does not support it, obviously).
> Any ideas? Maybe I am missing some configuration, but I could not figure out from the release notes if I needed to do something extra.
> This is on Mac OSX El Capitan, 10.11.6. I can try other platforms later but at the first sight this does not appear to be a platform-specific issue.
> *>>>>: ELW:*
> I would also like to try this on my platforms here at SLAC.
> Can you share what you have for your IOC?
> E.g. <TOP>/xxxApp/src/Makefile
> <TOP>/xxxApp/Db/*.db
> <TOP>/iocBoot/<ioc>/st.cmd
> ernesto@localhost (7.0) $ pwd
> /usr/local/controls/epics/base/R7.0.2/dbd
> ernesto@localhost (7.0) $ grep int64in *
> devSoft.dbd:device(int64in,CONSTANT,devI64inSoft,"Soft Channel")
> devSoft.dbd:device(int64in,CONSTANT,devI64inSoftCallback,"Async Soft Channel")
> int64inRecord.dbd:recordtype(int64in) {
> softIoc.dbd:recordtype(int64in) {
> softIoc.dbd:device(int64in, CONSTANT, devI64inSoft, "Soft Channel")
> softIoc.dbd:device(int64in, CONSTANT, devI64inSoftCallback, "Async Soft Channel")
> softIocPVA.dbd:recordtype(int64in) {
> softIocPVA.dbd:device(int64in, CONSTANT, devI64inSoft, "Soft Channel")
> softIocPVA.dbd:device(int64in, CONSTANT, devI64inSoftCallback, "Async Soft Channel")
> stdRecords.dbd:include "int64inRecord.dbd"
> Cheers,
> Ernesto
> Timo
- 64-bit records Timo Korhonen via Core-talk
- Re: 64-bit records Williams Jr., Ernest L. via Core-talk
Re: 64-bit records Michael Davidsaver via Core-talk
Jenkins build became unstable: epics-7.0 » mac #94 APS Jenkins via Core-talk
<2019>
<2019>
