Subject: |
Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
mdavidsaver <[email protected]> |
Date: |
Thu, 21 Nov 2013 17:48:18 -0000 |
Review: Needs Fixing
Michael, I'd like to merge this branch (I know, finally!), but there's no code in Base that actually uses the macros that it defines, so I don't know whether code using it would even compile for all our supported targets. If it had a test program that instantiated all the routines we would know that it compiles everywhere and can be linked into an executable that can be loaded. It also needs an announcement in the Release Notes, and documentation for the API in the Application Developers Guide (section 20.21 could probably use a major overhaul anyway).
https://code.launchpad.net/~epics-core/epics-base/devlib2mmio/+merge/163365
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
- [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base mdavidsaver
Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
[Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Andrew Johnson
<2013>
Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base Ben Franksen
Re: [Merge] lp:~epics-core/epics-base/devlib2mmio into lp:epics-base mdavidsaver
<2013>
