> > I notice that when building the R3.15 tip a "make clean" doesn't
> > actually remove any (most of) the files.
> This is definitely another issue with your setup, here's the start of my
> output from make clean:
You are correct. It turns out that placing the Gnu win32 make " C:\Program Files (x86)\GnuWin32\bin\" in the path causes the MSVC vcvars startup script to fail (probably due to DLL conflicts), and so I arrived at the solution of adding a doskey definition to the dos startup script as follows. My problems occurred due to not setting this dos key correctly, to pass parameters, on the first attempt. The dos key works differently compared to similar functionality in UNIX shells. Somehow without passing parameters I ended up building the install target when typing "make clean", which was an unexpected (i.e. confusing) outcome.
doskey make="C:\Program Files (x86)\GnuWin32\bin\make.exe" $1 $2 $3
Jeff
> -----Original Message-----
> From: [email protected] [mailto:core-talk-
> [email protected]] On Behalf Of Andrew Johnson
> Sent: Wednesday, November 20, 2013 9:44 AM
> To: [email protected]
> Subject: Re: make clean builds the install target on R3.15?
> Hi Jeff,
> D:\epics\mirror-3.15>make clean
> make -C ./configure clean
> make[1]: Entering directory `D:/epics/mirror-3.15/configure'
> perl -CSD -MExtUtils::Command -e rm_rf O.win32-x86 O.Common
> make[1]: Leaving directory `D:/epics/mirror-3.15/configure'
> make -C ./src clean
> make[1]: Entering directory `D:/epics/mirror-3.15/src'
> make -C ./tools clean
> make[2]: Entering directory `D:/epics/mirror-3.15/src/tools'
> make[2]: Leaving directory `D:/epics/mirror-3.15/src/tools'
> make -C tools/test clean
> make[2]: Entering directory `D:/epics/mirror-3.15/src/tools/test'
> make[2]: Leaving directory `D:/epics/mirror-3.15/src/tools/test'
> make -C template/base clean
> make[2]: Entering directory `D:/epics/mirror-3.15/src/template/base'
> make[2]: Leaving directory `D:/epics/mirror-3.15/src/template/base'
> make -C template/ext clean
> make[2]: Entering directory `D:/epics/mirror-3.15/src/template/ext'
> make[2]: Leaving directory `D:/epics/mirror-3.15/src/template/ext'
> make -C ./libCom clean
> make[2]: Entering directory `D:/epics/mirror-3.15/src/libCom'
> make[2]: Leaving directory `D:/epics/mirror-3.15/src/libCom'
> It makes no difference here whether the tree is initially populated or
> clean, I tried both.
> You need to investigate why the first sub-command that your make runs is
> not a clean but an install in the sub-directory:
> > C:\hill\epicsInBazaar\R3.15-mirror-II>make clean
> > C:/Program Files (x86)/GnuWin32/bin/make -C ./configure install
> - Andrew
> Advertising may be described as the science of arresting the human
> intelligence long enough to get money from it. -- Stephen Leacock
- make clean builds the install target on R3.15? Hill, Jeff
- Re: make clean builds the install target on R3.15? Andrew Johnson
Build failed in Jenkins: epics-base-3.15 #29 APS Jenkins
<2013>
[Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
<2013>
