I agree, no bug in the example - but why not add the call to close the
context to show best practice in the general case, even if you don't
show a put example?
I also agree with Jeff, doc could be improved - as I read it, it gave me
the strong impression that "flush" meant flush! - perhaps others will
make the same error of not reading the "fine print".
Cheers
Steve
On Tue, 2012-06-26 at 12:42 -0500, Andrew Johnson wrote:
> Hi Steve,
> On 2012-06-26 steve hunt wrote:
> > perhaps the next release could have the caclient makebase app
> > following this advice?
> The code in the caClient template works just fine. It calls ca_get(), so the
> subsequent ca_pend_io() won't return until the value has been received (or it
> times out, causing the SEVCHK() to fail). You were the one who changed the
> ca_get() call into ca_put(), which has different semantics as Jeff has
> explained. Now I agree that adding an example which uses ca_put() might be a
> good idea, but that's a different issue and doesn't represent a bug in the
> current example code.
> - Andrew
- Re: pend_io Andrew Johnson
- RE: pend_io Hill, Jeff
- Re: pend_io steve hunt
RE: pend_io Steve Hunt
<2012>
<2012>
