Hi All,
Sorry if I confused anyone with my earlier post.
On 2012-06-08 Ralph Lange wrote:
> On 08.06.2012 18:56, Hill, Jeff wrote:
> > Actually my understanding is that Ralph is requesting two action items.
> > 1) Remove the compensation in the epicsTimer class which subtracts one
> > half quantum from the timer's expiration time stamp. This is accepting
> > going to a new behavior where on average timers will expire one half tick
> > too late (the regression tests should verify this) but is presumably
> > needed because we prefer behavior where timers never expire as much as
> > one half tick too early (as is the case now).
This change sounds like it should occur in 3.15, so code can easily be written
to compensate for the behavior change depending on macros on epicsVersion.h.
> > 2) Make all epicsThreadSleep implementations follow the application
> > developer's guide and implement epicsThreadSleep(double ss) as follows.
> > ss <= 0.0 sleep for 0 ticks
> > 0 < ss <= 1 tick sleep for 1 tick (typical actual delay between 1
> > and 2 ticks)
> > 1 tick < ss <= 2 tick sleep for 2 ticks (typical actual delay between 2
> > and 3 ticks)
> > 2 tick < ss <= 3 tick sleep for 3 ticks (typical actual delay between 3
> > and 4 ticks)
IMHO any changes necessary to implement this are bug fixes and should be
committed to 3.14, since this is what the API was originally intended to do,
although the current appDevGuide wording doesn't make that completely obvious:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node21.html#14439
Can any of the existing libCom tests or performance measurements be used to
demonstrate what the epicsThreadSleep() code currently implements? If not, it
would be nice to have a test that fails when epicsThreadSleep() is not
implementing the right behavior, if that is detectable.
> I do see the use case for a statistically improved timer, though.
> For this I like Kay's idea of allowing the C++ timer class user to
> select the behavior through the API.
No objections from here, that would be a 3.15 (or 3.16)-level change. If you
want it in 3.15 though it needs to be published within the next week.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: epicsTimer and rounding Kasemir, Kay
- RE: epicsTimer and rounding Hill, Jeff
- Re: epicsTimer and rounding Ralph Lange
Re: epicsTimer and rounding Eric Norum
Re: "spinlock" API Andrew Johnson
<2012>
<2012>
