Ralph Lange has proposed merging lp:~ralph-lange/epics-base/fix-cpp-keywords into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
Related bugs:
#595240 C code uses C++ keywords as variable names
https://bugs.launchpad.net/bugs/595240
#595242 C code uses C++ "//" style comments
https://bugs.launchpad.net/bugs/595242
Replaced the C++ reserved word new where it was used as a variable name.
Replaced C++ "//" style comments with standard C comments where they were used in C code.
https://code.launchpad.net/~ralph-lange/epics-base/fix-cpp-keywords/+merge/27760
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/fix-cpp-keywords into lp:epics-base.
=== modified file 'src/db/db_access.c'
--- src/db/db_access.c 2009-03-10 18:51:03 +0000
+++ src/db/db_access.c 2010-06-16 20:03:31 +0000
@@ -246,15 +246,15 @@
struct dbr_sts_string *pold = (struct dbr_sts_string *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
DBSTRING *pvalue = (DBSTRING *)pold->value;
options = DBR_STATUS;
nRequest = 0;
- status = dbGetField(paddr, DBR_STRING, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_STRING, &newSt, &options, &nRequest,
pfl);
- pold->status = new.status;
- pold->severity = new.severity;
+ pold->status = newSt.status;
+ pold->severity = newSt.severity;
options = 0;
nRequest = no_elements;
status = dbGetField(paddr, DBR_STRING, pold->value, &options,
@@ -268,15 +268,15 @@
struct dbr_sts_int *pold = (struct dbr_sts_int *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
dbr_short_t *pvalue = &pold->value;
nRequest = 0;
- status = dbGetField(paddr, DBR_SHORT, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_SHORT, &newSt, &options, &nRequest,
pfl);
options = 0;
status = dbGetField(paddr, DBR_SHORT, &pold->value, &options,
@@ -289,15 +289,15 @@
struct dbr_sts_float *pold = (struct dbr_sts_float *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
dbr_float_t *pvalue = &pold->value;
nRequest = 0;
- status = dbGetField(paddr, DBR_FLOAT, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_FLOAT, &newSt, &options, &nRequest,
pfl);
options = 0;
status = dbGetField(paddr, DBR_FLOAT, &pold->value, &options,
@@ -310,15 +310,15 @@
struct dbr_sts_enum *pold = (struct dbr_sts_enum *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
dbr_enum_t *pvalue = &pold->value;
nRequest = 0;
- status = dbGetField(paddr, DBR_ENUM, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_ENUM, &newSt, &options, &nRequest,
pfl);
options = 0;
status = dbGetField(paddr, DBR_ENUM, &pold->value, &options,
@@ -331,15 +331,15 @@
struct dbr_sts_char *pold = (struct dbr_sts_char *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
dbr_char_t *pvalue = &pold->value;
nRequest = 0;
- status = dbGetField(paddr, DBR_UCHAR, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_UCHAR, &newSt, &options, &nRequest,
pfl);
options = 0;
status = dbGetField(paddr, DBR_UCHAR, &pold->value, &options,
@@ -352,15 +352,15 @@
struct dbr_sts_long *pold = (struct dbr_sts_long *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
dbr_long_t *pvalue = &pold->value;
nRequest = 0;
- status = dbGetField(paddr, DBR_LONG, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_LONG, &newSt, &options, &nRequest,
pfl);
options = 0;
status = dbGetField(paddr, DBR_LONG, &pold->value, &options,
@@ -373,15 +373,15 @@
struct dbr_sts_double *pold = (struct dbr_sts_double *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
dbr_double_t *pvalue = &pold->value;
nRequest = 0;
- status = dbGetField(paddr, DBR_DOUBLE, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_DOUBLE, &newSt, &options, &nRequest,
pfl);
options = 0;
status = dbGetField(paddr, DBR_DOUBLE, &pold->value, &options,
@@ -396,16 +396,16 @@
struct {
DBRstatus
DBRtime
- } new;
+ } newSt;
DBSTRING *pvalue = (DBSTRING *)(pold->value);
options = DBR_STATUS | DBR_TIME;
nRequest = 0;
pfl);
- pold->stamp = new.time; /* structure copy */
+ pold->stamp = newSt.time; /* structure copy */
options = 0;
@@ -420,16 +420,16 @@
struct {
DBRstatus
DBRtime
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -443,16 +443,16 @@
struct {
DBRstatus
DBRtime
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -466,16 +466,16 @@
struct {
DBRstatus
DBRtime
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -489,16 +489,16 @@
struct {
DBRstatus
DBRtime
- } new;
+ } newSt;
nRequest = 0;
- status = dbGetField(paddr, DBR_CHAR, &new, &options, &nRequest,
+ status = dbGetField(paddr, DBR_CHAR, &newSt, &options, &nRequest,
pfl);
options = 0;
status = dbGetField(paddr, DBR_CHAR, &pold->value, &options,
@@ -512,16 +512,16 @@
struct {
DBRstatus
DBRtime
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -535,16 +535,16 @@
struct {
DBRstatus
DBRtime
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -563,23 +563,23 @@
DBRunits
DBRgrLong
DBRalLong
- } new;
+ } newSt;
options = DBR_STATUS | DBR_UNITS | DBR_GR_LONG | DBR_AL_LONG;
nRequest = 0;
pfl);
- strncpy(pold->units, new.units, MAX_UNITS_SIZE);
+ strncpy(pold->units, newSt.units, MAX_UNITS_SIZE);
pold->units[MAX_UNITS_SIZE-1] = '\0';
- pold->upper_disp_limit = new.upper_disp_limit;
- pold->lower_disp_limit = new.lower_disp_limit;
- pold->upper_alarm_limit = new.upper_alarm_limit;
- pold->upper_warning_limit = new.upper_warning_limit;
- pold->lower_warning_limit = new.lower_warning_limit;
- pold->lower_alarm_limit = new.lower_alarm_limit;
+ pold->upper_disp_limit = newSt.upper_disp_limit;
+ pold->lower_disp_limit = newSt.lower_disp_limit;
+ pold->upper_alarm_limit = newSt.upper_alarm_limit;
+ pold->upper_warning_limit = newSt.upper_warning_limit;
+ pold->lower_warning_limit = newSt.lower_warning_limit;
+ pold->lower_alarm_limit = newSt.lower_alarm_limit;
options = 0;
@@ -596,25 +596,25 @@
DBRprecision
DBRgrDouble
DBRalDouble
- } new;
+ } newSt;
options = DBR_STATUS | DBR_UNITS | DBR_PRECISION | DBR_GR_DOUBLE |
DBR_AL_DOUBLE;
nRequest = 0;
pfl);
- pold->precision = new.precision.dp;
+ pold->precision = newSt.precision.dp;
- pold->upper_disp_limit = epicsConvertDoubleToFloat(new.upper_disp_limit);
- pold->lower_disp_limit = epicsConvertDoubleToFloat(new.lower_disp_limit);
- pold->upper_alarm_limit = epicsConvertDoubleToFloat(new.upper_alarm_limit);
- pold->lower_alarm_limit = epicsConvertDoubleToFloat(new.lower_alarm_limit);
- pold->upper_warning_limit = epicsConvertDoubleToFloat(new.upper_warning_limit);
- pold->lower_warning_limit = epicsConvertDoubleToFloat(new.lower_warning_limit);
+ pold->upper_disp_limit = epicsConvertDoubleToFloat(newSt.upper_disp_limit);
+ pold->lower_disp_limit = epicsConvertDoubleToFloat(newSt.lower_disp_limit);
+ pold->upper_alarm_limit = epicsConvertDoubleToFloat(newSt.upper_alarm_limit);
+ pold->lower_alarm_limit = epicsConvertDoubleToFloat(newSt.lower_alarm_limit);
+ pold->upper_warning_limit = epicsConvertDoubleToFloat(newSt.upper_warning_limit);
+ pold->lower_warning_limit = epicsConvertDoubleToFloat(newSt.lower_warning_limit);
options = 0;
@@ -631,23 +631,23 @@
DBRunits
DBRgrLong
DBRalLong
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -663,23 +663,23 @@
DBRunits
DBRgrLong
DBRalLong
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -696,25 +696,25 @@
DBRprecision
DBRgrDouble
DBRalDouble
- } new;
+ } newSt;
DBR_AL_DOUBLE;
nRequest = 0;
pfl);
options = 0;
@@ -733,26 +733,26 @@
DBRgrLong
DBRctrlLong
DBRalLong
- } new;
+ } newSt;
options = DBR_STATUS | DBR_UNITS | DBR_GR_LONG | DBR_CTRL_LONG |
DBR_AL_LONG;
nRequest = 0;
pfl);
- pold->upper_ctrl_limit = new.upper_ctrl_limit;
- pold->lower_ctrl_limit = new.lower_ctrl_limit;
+ pold->upper_ctrl_limit = newSt.upper_ctrl_limit;
+ pold->lower_ctrl_limit = newSt.lower_ctrl_limit;
options = 0;
@@ -770,27 +770,27 @@
DBRgrDouble
DBRctrlDouble
DBRalDouble
- } new;
+ } newSt;
DBR_CTRL_DOUBLE | DBR_AL_DOUBLE;
nRequest = 0;
pfl);
- pold->upper_ctrl_limit = epicsConvertDoubleToFloat(new.upper_ctrl_limit);
- pold->lower_ctrl_limit = epicsConvertDoubleToFloat(new.lower_ctrl_limit);
+ pold->upper_ctrl_limit = epicsConvertDoubleToFloat(newSt.upper_ctrl_limit);
+ pold->lower_ctrl_limit = epicsConvertDoubleToFloat(newSt.lower_ctrl_limit);
options = 0;
@@ -805,7 +805,7 @@
struct {
DBRstatus
DBRenumStrs
- } new;
+ } newSt;
short no_str;
@@ -813,15 +813,15 @@
/* first get status and severity */
options = DBR_STATUS | DBR_ENUM_STRS;
nRequest = 0;
pfl);
- no_str = new.no_str;
+ no_str = newSt.no_str;
if (no_str>16) no_str=16;
pold->no_str = no_str;
for (i = 0; i < no_str; i++)
- strncpy(pold->strs[i], new.strs[i], sizeof(pold->strs[i]));
+ strncpy(pold->strs[i], newSt.strs[i], sizeof(pold->strs[i]));
/*now get values*/
options = 0;
@@ -839,26 +839,26 @@
DBRgrLong
DBRctrlLong
DBRalLong
- } new;
+ } newSt;
DBR_AL_LONG;
nRequest = 0;
pfl);
options = 0;
@@ -875,26 +875,26 @@
DBRgrLong
DBRctrlLong
DBRalLong
- } new;
+ } newSt;
DBR_AL_LONG;
nRequest = 0;
pfl);
options = 0;
@@ -912,27 +912,27 @@
DBRgrDouble
DBRctrlDouble
DBRalDouble
- } new;
+ } newSt;
nRequest = 0;
pfl);
options = 0;
@@ -946,17 +946,17 @@
struct dbr_stsack_string *pold = (struct dbr_stsack_string *)pbuffer;
struct {
DBRstatus
- } new;
+ } newSt;
nRequest = 0;
pfl);
- pold->ackt = new.ackt;
- pold->acks = new.acks;
+ pold->ackt = newSt.ackt;
+ pold->acks = newSt.acks;
options = 0;
=== modified file 'src/dbStatic/dbStaticLib.c'
--- src/dbStatic/dbStaticLib.c 2009-08-03 22:22:45 +0000
+++ src/dbStatic/dbStaticLib.c 2010-06-16 20:03:31 +0000
@@ -516,14 +516,14 @@
/* Beginning of Public Routines */
#define INC_SIZE 256
-void epicsShareAPI dbCatString(char **string,int *stringLength,char *new,char *separator)
+void epicsShareAPI dbCatString(char **string,int *stringLength,char *src,char *separator)
if((*string==NULL)
- || ((strlen(*string)+strlen(new)+2) > (size_t)*stringLength)) {
+ || ((strlen(*string)+strlen(src)+2) > (size_t)*stringLength)) {
char *newString;
size_t size;
- size = strlen(new);
+ size = strlen(src);
if(*string) size += strlen(*string);
/*Make size multiple of INC_SIZE*/
size = ((size + 2 + INC_SIZE)/INC_SIZE) * INC_SIZE;
@@ -538,8 +538,8 @@
strcat(*string,separator);
*stringLength += strlen(separator);
- strcat(*string,new);
- *stringLength += strlen(new);
+ strcat(*string,src);
+ *stringLength += strlen(src);
dbBase * epicsShareAPI dbAllocBase(void)
=== modified file 'src/libCom/osi/os/WIN32/osdProcess.c'
--- src/libCom/osi/os/WIN32/osdProcess.c 2002-11-26 23:24:16 +0000
+++ src/libCom/osi/os/WIN32/osdProcess.c 2010-06-16 20:03:31 +0000
@@ -64,16 +64,16 @@
startupInfo.wShowWindow = SW_SHOWMINNOACTIVE;
status = CreateProcess (
- NULL, // pointer to name of executable module (not required if command line is specified)
- (char *) pBaseExecutableName, // pointer to command line string
- NULL, // pointer to process security attributes
- NULL, // pointer to thread security attributes
- FALSE, // handle inheritance flag
- CREATE_NEW_PROCESS_GROUP | DETACHED_PROCESS, // creation flags
- NULL, // pointer to new environment block (defaults to caller's environement)
- NULL, // pointer to current directory name (defaults to caller's current directory)
- &startupInfo, // pointer to STARTUPINFO
- &processInfo // pointer to PROCESS_INFORMATION
+ NULL, /* pointer to name of executable module (not required if command line is specified) */
+ (char *) pBaseExecutableName, /* pointer to command line string */
+ NULL, /* pointer to process security attributes */
+ NULL, /* pointer to thread security attributes */
+ FALSE, /* handle inheritance flag */
+ CREATE_NEW_PROCESS_GROUP | DETACHED_PROCESS, /* creation flags */
+ NULL, /* pointer to new environment block (defaults to caller's environement) */
+ NULL, /* pointer to current directory name (defaults to caller's current directory) */
+ &startupInfo, /* pointer to STARTUPINFO */
+ &processInfo /* pointer to PROCESS_INFORMATION */
if ( status == 0 ) {
DWORD W32status;
@@ -84,7 +84,7 @@
FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
NULL,
GetLastError (),
- MAKELANGID (LANG_NEUTRAL, SUBLANG_DEFAULT), // Default language
+ MAKELANGID (LANG_NEUTRAL, SUBLANG_DEFAULT), /* Default language */
(LPTSTR) &errStrMsgBuf,
0,
NULL
@@ -107,24 +107,24 @@
FORMAT_MESSAGE_ARGUMENT_ARRAY | 80,
"%1 \"%2\". %3 %4 %5 \"%6\"",
0,
(LPTSTR) &complteMsgBuf,
0,
pFmtArgs
if (W32status) {
- // Display the string.
+ /* Display the string. */
MessageBox (NULL, complteMsgBuf, "Configuration Problem",
MB_OK | MB_ICONINFORMATION);
LocalFree (complteMsgBuf);
else {
MessageBox (NULL, errStrMsgBuf, "Failed to start executable",
- // Free the buffer.
+ /* Free the buffer. */
LocalFree (errStrMsgBuf);
else {
@@ -137,16 +137,17 @@
return osiSpawnDetachedProcessSuccess;
- // use of spawn here causes problems when the ca repeater
- // inherits open files (and sockets) from the spawning
- // process
- //status = _spawnlp (_P_DETACH, pBaseExecutableName, pBaseExecutableName, NULL);
- //if (status<0) {
- // errlogPrintf ("!!WARNING!!\n");
- // errlogPrintf ("Unable to locate the EPICS executable \"%s\".\n",
- // pBaseExecutableName);
- // errlogPrintf ("You may need to modify your environment.\n");
+ use of spawn here causes problems when the ca repeater
+ inherits open files (and sockets) from the spawning
+ process
+ status = _spawnlp (_P_DETACH, pBaseExecutableName, pBaseExecutableName, NULL);
+ if (status<0) {
+ errlogPrintf ("!!WARNING!!\n");
+ errlogPrintf ("Unable to locate the EPICS executable \"%s\".\n",
+ pBaseExecutableName);
+ errlogPrintf ("You may need to modify your environment.\n");
- Re: [Merge] lp:~ralph-lange/epics-base/fix-cpp-keywords into lp:epics-base Nick Rees
- Re: [Merge] lp:~ralph-lange/epics-base/fix-cpp-keywords into lp:epics-base Michael Abbott
RE: Using C++ keywords as variable names in C code Jeff Hill
<2010>
<2010>
