Subject: |
[Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base |
Dirk Zimoch <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 27 May 2010 15:14:25 -0000 |
Dirk Zimoch has proposed merging lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
The attributes (units, precision, graphic and control limits) of non-VAL fields used to be mainly nonsense.
Now EGU and PREC are used only for VAL-equivalent fields (i.e.VAL, OVAL, HOPR, LOPR,...). (The histogram record is an exception as it uses units and precision on its input, not on the VAL field, which is an array of counters.)
Records with variable type (->FTVL) now ignore EGU for the VAL field when using STRING or ENUM types.
All delay fields (bo.HIGH, seq.DLYn, calcout.ODLY) now report precision=2, units="s", graphic limits=0...10.
Calc-like records with many inputs of probably different units and precisions (calc, calcout, sub, aSub, seq) now fetch the attributes of these values (A...L, LA...LL) from the corresponding INPn link (aSub.VALn from the corresponding OUTn link). Constant links get precision and units from PREC and EGU if possible, precision=15 and units="" otherwise.
Discussion and future work:
* Set the severity and status attributes only on the VAL field?
* Should SPC_NOMOD fields report Nan for control limits?
* Precision is limited to 0...15 for most double fields except VAL. Remove this feature and trust the user?
* Implement common code for similar records (like base classes). This might involve re-ordering of the fields and may expand the number of similar inputs to a common number for calc-like records. This is probably a separate work package.
https://code.launchpad.net/~dirk.zimoch/epics-base/non-val-attributes/+merge/26189
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base.
=== modified file 'src/rec/aSubRecord.c'
--- src/rec/aSubRecord.c 2010-04-20 22:13:54 +0000
+++ src/rec/aSubRecord.c 2010-05-27 15:14:24 +0000
@@ -53,14 +53,14 @@
static long cvt_dbaddr(DBADDR *);
static long get_array_info(DBADDR *, long *, long *);
static long put_array_info(DBADDR *, long );
-#define get_units NULL
+static long get_units(DBADDR *, char *);
static long get_precision(DBADDR *, long *);
#define get_enum_str NULL
#define get_enum_strs NULL
#define put_enum_str NULL
-#define get_graphic_double NULL
-#define get_control_double NULL
-#define get_alarm_double NULL
+static long get_graphic_double(DBADDR *, struct dbr_grDouble *);
+static long get_control_double(DBADDR *, struct dbr_ctrlDouble *);
+static long get_alarm_double(DBADDR *, struct dbr_alDouble *);
rset aSubRSET = {
RSETNUMBER,
@@ -330,15 +330,116 @@
return 0;
-static long get_precision(DBADDR *paddr, long *precision)
- aSubRecord *prec = (aSubRecord *)paddr->precord;
- *precision = prec->prec;
- recGblGetPrec(paddr, precision);
- return 0;
+#define indexof(field) aSubRecord##field
+static long get_inlinkNumber(int fieldIndex) {
+ if (fieldIndex >= indexof(A) && fieldIndex <= indexof(U))
+ return fieldIndex - indexof(A);
+ return -1;
+static long get_outlinkNumber(int fieldIndex) {
+ if (fieldIndex >= indexof(VALA) && fieldIndex <= indexof(VALU))
+ return fieldIndex - indexof(VALA);
+ return -1;
+static long get_units(DBADDR *paddr, char *units)
+ aSubRecord *prec = (aSubRecord *)paddr->precord;
+ int linkNumber;
+ linkNumber = get_inlinkNumber(dbGetFieldIndex(paddr));
+ if (linkNumber >= 0) {
+ dbGetUnits(&prec->inpa + linkNumber, units, DB_UNITS_SIZE);
+ return 0;
+ linkNumber = get_outlinkNumber(dbGetFieldIndex(paddr));
+ dbGetUnits(&prec->outa + linkNumber, units, DB_UNITS_SIZE);
+ return 0;
+static long get_precision(DBADDR *paddr, long *pprecision)
+ int fieldIndex = dbGetFieldIndex(paddr);
+ int linkNumber;
+ short precision;
+ *pprecision = prec->prec;
+ linkNumber = get_inlinkNumber(fieldIndex);
+ if (dbGetPrecision(&prec->inpa + linkNumber, &precision) == 0)
+ *pprecision = precision;
+ return 0;
+ linkNumber = get_outlinkNumber(fieldIndex);
+ if (dbGetPrecision(&prec->outa + linkNumber, &precision) == 0)
+ return 0;
+ recGblGetPrec(paddr, pprecision);
+ return 0;
+static long get_graphic_double(DBADDR *paddr, struct dbr_grDouble *pgd)
+ int linkNumber;
+ dbGetGraphicLimits(&prec->inpa + linkNumber,
+ &pgd->lower_disp_limit,
+ &pgd->upper_disp_limit);
+ return 0;
+ dbGetGraphicLimits(&prec->outa + linkNumber,
+ return 0;
+static long get_control_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd)
+ recGblGetControlDouble(paddr,pcd);
+ return 0;
+static long get_alarm_double(DBADDR *paddr, struct dbr_alDouble *pad)
+ int linkNumber;
+ dbGetAlarmLimits(&prec->inpa + linkNumber,
+ &pad->lower_alarm_limit,
+ &pad->lower_warning_limit,
+ &pad->upper_warning_limit,
+ &pad->upper_alarm_limit);
+ return 0;
+ dbGetAlarmLimits(&prec->outa + linkNumber,
+ return 0;
+ recGblGetAlarmDouble(paddr, pad);
+ return 0;
static void monitor(aSubRecord *prec)
=== modified file 'src/rec/aaiRecord.c'
--- src/rec/aaiRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/aaiRecord.c 2010-05-27 15:14:24 +0000
@@ -191,11 +191,20 @@
return 0;
+#define indexof(field) aaiRecord##field
aaiRecord *prec = (aaiRecord *)paddr->precord;
- strncpy(units, prec->egu, DB_UNITS_SIZE);
+ switch (dbGetFieldIndex(paddr)) {
+ case indexof(VAL):
+ if (prec->ftvl == DBF_STRING || prec->ftvl == DBF_ENUM)
+ break;
+ case indexof(HOPR):
+ case indexof(LOPR):
+ strncpy(units,prec->egu,DB_UNITS_SIZE);
return 0;
@@ -204,8 +213,8 @@
- if (paddr->pfield == (void *)prec->bptr) return 0;
+ if (dbGetFieldIndex(paddr) != indexof(VAL))
+ recGblGetPrec(paddr, precision);
return 0;
@@ -213,10 +222,18 @@
- if (paddr->pfield == (void *)prec->bptr) {
- pgd->upper_disp_limit = prec->hopr;
- pgd->lower_disp_limit = prec->lopr;
- } else recGblGetGraphicDouble(paddr, pgd);
+ pgd->upper_disp_limit = prec->hopr;
+ pgd->lower_disp_limit = prec->lopr;
+ break;
+ case indexof(NORD):
+ pgd->upper_disp_limit = prec->nelm;
+ pgd->lower_disp_limit = 0;
+ break;
+ default:
+ recGblGetGraphicDouble(paddr, pgd);
return 0;
@@ -224,10 +241,18 @@
- pcd->upper_ctrl_limit = prec->hopr;
- pcd->lower_ctrl_limit = prec->lopr;
- } else recGblGetControlDouble(paddr, pcd);
+ pcd->upper_ctrl_limit = prec->hopr;
+ pcd->lower_ctrl_limit = prec->lopr;
+ break;
+ pcd->upper_ctrl_limit = prec->nelm;
+ pcd->lower_ctrl_limit = 0;
+ break;
+ default:
+ recGblGetControlDouble(paddr, pcd);
return 0;
=== modified file 'src/rec/aaoRecord.c'
--- src/rec/aaoRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/aaoRecord.c 2010-05-27 15:14:24 +0000
@@ -188,11 +188,20 @@
return 0;
+#define indexof(field) aaoRecord##field
aaoRecord *prec = (aaoRecord *)paddr->precord;
+ break;
return 0;
@@ -201,8 +210,8 @@
return 0;
@@ -210,10 +219,18 @@
- } else recGblGetGraphicDouble(paddr,pgd);
+ break;
+ break;
+ default:
return 0;
@@ -221,10 +238,18 @@
- if(paddr->pfield==(void *)prec->bptr){
- } else recGblGetControlDouble(paddr,pcd);
+ break;
+ break;
+ default:
return 0;
=== modified file 'src/rec/aiRecord.c'
--- src/rec/aiRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/aiRecord.c 2010-05-27 15:14:24 +0000
@@ -217,11 +217,22 @@
+#define indexof(field) aiRecord##field
aiRecord *prec=(aiRecord *)paddr->precord;
- strncpy(units,prec->egu,DB_UNITS_SIZE);
+ if(paddr->pfldDes->field_type == DBF_DOUBLE) {
+ case indexof(ASLO):
+ case indexof(AOFF):
+ case indexof(SMOO):
+ break;
+ default:
return(0);
@@ -230,7 +241,7 @@
- if(paddr->pfield == (void *)&prec->val) return(0);
+ if (dbGetFieldIndex(paddr) == indexof(VAL)) return(0);
recGblGetPrec(paddr,precision);
return(0);
@@ -238,43 +249,54 @@
static long get_graphic_double(DBADDR *paddr,struct dbr_grDouble *pgd)
- int fieldIndex = dbGetFieldIndex(paddr);
- if(fieldIndex == aiRecordVAL
- || fieldIndex == aiRecordHIHI
- || fieldIndex == aiRecordHIGH
- || fieldIndex == aiRecordLOW
- || fieldIndex == aiRecordLOLO
- || fieldIndex == aiRecordHOPR
- || fieldIndex == aiRecordLOPR) {
+ case indexof(HIHI):
+ case indexof(HIGH):
+ case indexof(LOW):
+ case indexof(LOLO):
+ case indexof(LALM):
+ case indexof(ALST):
+ case indexof(MLST):
+ case indexof(SVAL):
+ break;
+ default:
+ recGblGetGraphicDouble(paddr,pgd);
return(0);
static long get_control_double(DBADDR *paddr,struct dbr_ctrlDouble *pcd)
- || fieldIndex == aiRecordLOLO) {
+ break;
+ default:
return(0);
static long get_alarm_double(DBADDR *paddr,struct dbr_alDouble *pad)
- if(fieldIndex == aiRecordVAL) {
+ if (dbGetFieldIndex(paddr) == indexof(VAL)) {
pad->upper_alarm_limit = prec->hhsv ? prec->hihi : epicsNAN;
pad->upper_warning_limit = prec->hsv ? prec->high : epicsNAN;
pad->lower_warning_limit = prec->lsv ? prec->low : epicsNAN;
=== modified file 'src/rec/aoRecord.c'
--- src/rec/aoRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/aoRecord.c 2010-05-27 15:14:24 +0000
@@ -276,11 +276,21 @@
+#define indexof(field) aoRecord##field
static long get_units(DBADDR * paddr,char *units)
aoRecord *prec=(aoRecord *)paddr->precord;
+ break;
+ default:
return(0);
@@ -289,10 +299,14 @@
- || paddr->pfield == (void *)&prec->oval
- || paddr->pfield == (void *)&prec->pval) return(0);
- recGblGetPrec(paddr,precision);
+ case indexof(OVAL):
+ case indexof(PVAL):
+ break;
+ default:
+ recGblGetPrec(paddr,precision);
return(0);
@@ -300,16 +314,24 @@
- if(paddr->pfield==(void *)&prec->val
- || paddr->pfield==(void *)&prec->hihi
- || paddr->pfield==(void *)&prec->high
- || paddr->pfield==(void *)&prec->low
- || paddr->pfield==(void *)&prec->lolo
- || paddr->pfield==(void *)&prec->oval
- || paddr->pfield==(void *)&prec->pval){
+ case indexof(IVOV):
+ break;
+ default:
return(0);
@@ -317,23 +339,30 @@
- pcd->upper_ctrl_limit = prec->drvh;
- pcd->lower_ctrl_limit = prec->drvl;
+ pcd->upper_ctrl_limit = prec->drvh;
+ pcd->lower_ctrl_limit = prec->drvl;
+ break;
+ default:
return(0);
- if(paddr->pfield==(void *)&prec->val){
+ if(dbGetFieldIndex(paddr) == indexof(VAL)){
=== modified file 'src/rec/boRecord.c'
--- src/rec/boRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/boRecord.c 2010-05-27 15:14:24 +0000
@@ -51,13 +51,13 @@
#define cvt_dbaddr NULL
#define get_array_info NULL
#define put_array_info NULL
static long get_enum_str(DBADDR *, char *);
static long get_enum_strs(DBADDR *, struct dbr_enumStrs *);
static long put_enum_str(DBADDR *, char *);
rset boRSET={
@@ -268,12 +268,31 @@
return(status);
+#define indexof(field) boRecord##field
+ if(dbGetFieldIndex(paddr) == indexof(HIGH))
+ strcpy(units, "s");
+ return(0);
- boRecord *prec=(boRecord *)paddr->precord;
+ *precision = 2;
+ else
+ return(0);
- if(paddr->pfield == (void *)&prec->high) *precision=2;
- else recGblGetPrec(paddr,precision);
+static long get_control_double(DBADDR *paddr,struct dbr_ctrlDouble *pcd)
+ if(dbGetFieldIndex(paddr) == indexof(HIGH)) {
+ pcd->lower_ctrl_limit = 0.0;
+ pcd->upper_ctrl_limit = 10.0;
+ } else
return(0);
@@ -285,7 +304,7 @@
index = dbGetFieldIndex(paddr);
- if(index!=boRecordVAL) {
+ if(index!=indexof(VAL)) {
strcpy(pstring,"Illegal_Value");
} else if(*pfield==0) {
strncpy(pstring,prec->znam,sizeof(prec->znam));
=== modified file 'src/rec/calcRecord.c'
--- src/rec/calcRecord.c 2009-04-03 14:40:13 +0000
+++ src/rec/calcRecord.c 2010-05-27 15:14:24 +0000
@@ -54,7 +54,7 @@
static long get_graphic_double(DBADDR *paddr, struct dbr_grDouble *pgd);
-static long get_ctrl_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd);
+static long get_control_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd);
static long get_alarm_double(DBADDR *paddr, struct dbr_alDouble *pad);
rset calcRSET={
@@ -74,7 +74,7 @@
get_enum_strs,
put_enum_str,
get_graphic_double,
- get_ctrl_double,
+ get_control_double,
get_alarm_double
epicsExportAddress(rset, calcRSET);
@@ -148,97 +148,126 @@
return S_db_badChoice;
+#define indexof(field) calcRecord##field
+static long get_linkNumber(int fieldIndex) {
+ if (fieldIndex >= indexof(A) && fieldIndex <= indexof(L))
+ if (fieldIndex >= indexof(LA) && fieldIndex <= indexof(LL))
+ return fieldIndex - indexof(LA);
+ return -1;
calcRecord *prec = (calcRecord *)paddr->precord;
+ int linkNumber;
+ linkNumber = get_linkNumber(dbGetFieldIndex(paddr));
+ else
return 0;
+ int linkNumber;
- if (paddr->pfield == (void *)&prec->val) {
- *pprecision = prec->prec;
- } else {
- recGblGetPrec(paddr, pprecision);
+ if (fieldIndex == indexof(VAL)) {
+ return 0;
+ linkNumber = get_linkNumber(fieldIndex);
+ short precision;
+ else
+ *pprecision = 15;
+ } else
return 0;
- if (paddr->pfield == (void *)&prec->val ||
- paddr->pfield == (void *)&prec->hihi ||
- paddr->pfield == (void *)&prec->high ||
- paddr->pfield == (void *)&prec->low ||
- paddr->pfield == (void *)&prec->lolo) {
- return 0;
- if (paddr->pfield >= (void *)&prec->a &&
- paddr->pfield <= (void *)&prec->l) {
- return 0;
- if (paddr->pfield >= (void *)&prec->la &&
- paddr->pfield <= (void *)&prec->ll) {
- return 0;
- recGblGetGraphicDouble(paddr, pgd);
+ int linkNumber;
+ switch (fieldIndex) {
+ break;
+ default:
+ } else
return 0;
- return 0;
- return 0;
- return 0;
- recGblGetControlDouble(paddr, pcd);
+ break;
+ default:
return 0;
+ int linkNumber;
+ pad->lower_alarm_limit = prec->llsv ? prec->lolo : epicsNAN;
+ pad->lower_warning_limit = prec->lsv ? prec->low : epicsNAN;
+ pad->upper_warning_limit = prec->hsv ? prec->high : epicsNAN;
- pad->upper_warning_limit = prec->hsv ? prec->high : epicsNAN;
- pad->lower_warning_limit = prec->lsv ? prec->low : epicsNAN;
- pad->lower_alarm_limit = prec->llsv ? prec->lolo : epicsNAN;
} else {
- recGblGetAlarmDouble(paddr, pad);
+ } else
return 0;
=== modified file 'src/rec/calcoutRecord.c'
--- src/rec/calcoutRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/calcoutRecord.c 2010-05-27 15:14:24 +0000
@@ -59,7 +59,7 @@
-static long get_ctrl_double(DBADDR *, struct dbr_ctrlDouble *);
rset calcoutRSET = {
@@ -79,7 +79,7 @@
get_enum_strs,
put_enum_str,
get_graphic_double,
- get_ctrl_double,
get_alarm_double
epicsExportAddress(rset, calcoutRSET);
@@ -363,97 +363,144 @@
+#define indexof(field) calcoutRecord##field
+ return -1;
calcoutRecord *prec = (calcoutRecord *)paddr->precord;
+ int linkNumber;
+ if(fieldIndex == indexof(ODLY)) {
+ return 0;
+ else
return 0;
+ int linkNumber;
- } else {
+ *pprecision = 2;
+ return 0;
+ return 0;
+ short precision;
+ else
+ *pprecision = 15;
+ } else
return 0;
- return 0;
- return 0;
- return 0;
+ int linkNumber;
+ break;
+ case indexof(ODLY):
+ pgd->lower_disp_limit = 0.0;
+ break;
+ default:
+ } else
return 0;
- return 0;
- return 0;
- return 0;
+ break;
+ break;
+ default:
return 0;
+ int linkNumber;
} else {
+ } else
return 0;
=== modified file 'src/rec/compressRecord.c'
--- src/rec/compressRecord.c 2010-04-02 21:26:17 +0000
+++ src/rec/compressRecord.c 2010-05-27 15:14:24 +0000
@@ -398,11 +398,16 @@
return(0);
+#define indexof(field) compressRecord##field
static long get_units(DBADDR *paddr,char *units)
compressRecord *prec=(compressRecord *)paddr->precord;
+ || dbGetFieldIndex(paddr) == indexof(VAL)) {
return(0);
@@ -411,7 +416,7 @@
- if(paddr->pfield == (void *)prec->bptr) return(0);
+ if(dbGetFieldIndex(paddr) == indexof(BPTR)) return(0);
return(0);
@@ -420,12 +425,16 @@
- || paddr->pfield==(void *)&prec->ihil
- || paddr->pfield==(void *)&prec->ilil){
+ case indexof(BPTR):
+ case indexof(IHIL):
+ case indexof(ILIL):
+ break;
+ default:
return(0);
@@ -433,11 +442,15 @@
+ break;
+ default:
return(0);
=== modified file 'src/rec/dfanoutRecord.c'
--- src/rec/dfanoutRecord.c 2009-04-03 14:40:13 +0000
+++ src/rec/dfanoutRecord.c 2010-05-27 15:14:24 +0000
@@ -126,73 +126,72 @@
return(status);
+#define indexof(field) dfanoutRecord##field
dfanoutRecord *prec=(dfanoutRecord *)paddr->precord;
return(0);
static long get_precision(DBADDR *paddr,long *precision)
- if(fieldIndex == dfanoutRecordVAL
- || fieldIndex == dfanoutRecordHIHI
- || fieldIndex == dfanoutRecordHIGH
- || fieldIndex == dfanoutRecordLOW
- || fieldIndex == dfanoutRecordLOLO
- || fieldIndex == dfanoutRecordHOPR
- || fieldIndex == dfanoutRecordLOPR) {
- } else {
+ *precision = prec->prec;
+ return(0);
+static long get_graphic_double(DBADDR *paddr,struct dbr_grDouble *pgd)
+ dfanoutRecord *prec=(dfanoutRecord *)paddr->precord;
+ break;
+ default:
return(0);
-static long get_graphic_double(DBADDR *paddr,struct dbr_grDouble *pgd)
- dfanoutRecord *prec=(dfanoutRecord *)paddr->precord;
- return(0);
- || fieldIndex == dfanoutRecordLOLO) {
+ break;
+ default:
return(0);
- if(fieldIndex == dfanoutRecordVAL) {
+ if(dbGetFieldIndex(paddr) == indexof(VAL)) {
=== modified file 'src/rec/histogramRecord.c'
--- src/rec/histogramRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/histogramRecord.c 2010-05-27 15:14:24 +0000
@@ -52,7 +52,7 @@
static long get_precision(DBADDR *paddr,long *precision);
@@ -386,42 +386,71 @@
return(status);
+#define indexof(field) histogramRecord##field
+ if (dbGetFieldIndex(paddr) == indexof(SDEL)) {
+ strcpy(units,"s");
+ /* We should have EGU for other DOUBLE values or probably get it from input link SVL */
+ return(0);
histogramRecord *prec=(histogramRecord *)paddr->precord;
- if(fieldIndex == histogramRecordULIM
- || fieldIndex == histogramRecordLLIM
- || fieldIndex == histogramRecordSDEL
- || fieldIndex == histogramRecordSGNL
- || fieldIndex == histogramRecordSVAL
- || fieldIndex == histogramRecordWDTH) {
+ case indexof(ULIM):
+ case indexof(LLIM):
+ case indexof(SGNL):
+ case indexof(WDTH):
+ break;
+ case indexof(SDEL):
+ *precision = 2;
+ break;
+ default:
return(0);
- if(fieldIndex == histogramRecordBPTR){
+ break;
+ pgd->upper_disp_limit = prec->ulim-prec->llim;
+ break;
+ default:
return(0);
+ break;
+ pcd->upper_ctrl_limit = prec->ulim-prec->llim;
+ break;
+ default:
return(0);
=== modified file 'src/rec/longinRecord.c'
--- src/rec/longinRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/longinRecord.c 2010-05-27 15:14:24 +0000
@@ -158,11 +158,15 @@
return(status);
+#define indexof(field) longinRecord##field
longinRecord *prec=(longinRecord *)paddr->precord;
+ if(paddr->pfldDes->field_type == DBF_LONG) {
return(0);
@@ -171,14 +175,22 @@
- || paddr->pfield==(void *)&prec->lolo){
+ break;
+ default:
return(0);
@@ -186,14 +198,22 @@
+ break;
+ default:
return(0);
@@ -201,7 +221,7 @@
pad->upper_alarm_limit = prec->hihi;
pad->upper_warning_limit = prec->high;
pad->lower_warning_limit = prec->low;
=== modified file 'src/rec/longoutRecord.c'
--- src/rec/longoutRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/longoutRecord.c 2010-05-27 15:14:24 +0000
@@ -190,58 +190,73 @@
return(status);
+#define indexof(field) longoutRecord##field
longoutRecord *prec=(longoutRecord *)paddr->precord;
return(0);
- if(fieldIndex == longoutRecordVAL
- || fieldIndex == longoutRecordHIHI
- || fieldIndex == longoutRecordHIGH
- || fieldIndex == longoutRecordLOW
- || fieldIndex == longoutRecordLOLO) {
+ break;
+ default:
return(0);
- /* do not change pre drvh/drvl behavior */
- if(prec->drvh > prec->drvl) {
- } else {
+ /* do not change pre drvh/drvl behavior */
+ if(prec->drvh > prec->drvl) {
+ } else {
+ break;
+ default:
return(0);
- if(fieldIndex == longoutRecordVAL) {
=== modified file 'src/rec/selRecord.c'
--- src/rec/selRecord.c 2009-08-25 18:19:49 +0000
+++ src/rec/selRecord.c 2010-05-27 15:14:24 +0000
@@ -132,11 +132,15 @@
+#define indexof(field) selRecord##field
selRecord *prec=(selRecord *)paddr->precord;
return(0);
@@ -166,56 +170,68 @@
- return(0);
- if(paddr->pfield>=(void *)&prec->a && paddr->pfield<=(void *)&prec->l){
- return(0);
- if(paddr->pfield>=(void *)&prec->la && paddr->pfield<=(void *)&prec->ll){
- return(0);
- recGblGetGraphicDouble(paddr,pgd);
+ int index = dbGetFieldIndex(paddr);
+ switch (index) {
+#ifdef __GNUC__
+ case indexof(A) ... indexof(L):
+ case indexof(LA) ... indexof(LL):
+ break;
+ default:
+#else
+ break;
+ default:
+ if((index >= indexof(A) && index <= indexof(L))
+ || (index >= indexof(LA) && index <= indexof(LL)))
+ break;
+#endif
+ return(0);
return(0);
static long get_control_double(struct dbAddr *paddr, struct dbr_ctrlDouble *pcd)
- return(0);
- return(0);
- return(0);
- recGblGetControlDouble(paddr,pcd);
+ switch (index) {
+#ifdef __GNUC__
+ break;
+ default:
+#else
+ break;
+ default:
+ break;
+#endif
+ return(0);
return(0);
@@ -223,7 +239,7 @@
- if(paddr->pfield==(void *)&prec->val ){
=== modified file 'src/rec/seqRecord.c'
--- src/rec/seqRecord.c 2009-04-02 21:41:45 +0000
+++ src/rec/seqRecord.c 2010-05-27 15:14:24 +0000
@@ -6,7 +6,7 @@
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
* $Id$
@@ -39,34 +39,48 @@
int seqRecDebug = 0;
+static int processNextLink(seqRecord *prec);
+static long asyncFinish(seqRecord *prec);
+static void processCallback(CALLBACK *arg);
/* Create RSET - Record Support Entry Table*/
+#define report NULL
+#define initialize NULL
static long init_record(seqRecord *prec, int pass);
static long process(seqRecord *prec);
-static int processNextLink(seqRecord *prec);
-static long asyncFinish(seqRecord *prec);
-static void processCallback(CALLBACK *arg);
-static long get_precision(dbAddr *paddr, long *pprecision);
+#define special NULL
+#define get_value NULL
+#define cvt_dbaddr NULL
+#define get_array_info NULL
+#define put_array_info NULL
+static long get_precision(dbAddr *paddr, long *);
+#define get_enum_str NULL
+#define get_enum_strs NULL
+#define put_enum_str NULL
rset seqRSET={
RSETNUMBER,
- NULL, /* report */
- NULL, /* initialize */
+ report, /* report */
+ initialize, /* initialize */
init_record, /* init_record */
process, /* process */
- NULL, /* special */
- NULL, /* get_value */
- NULL, /* cvt_dbaddr */
- NULL, /* get_array_info */
- NULL, /* put_array_info */
- NULL, /* get_units */
+ special, /* special */
+ get_value, /* get_value */
+ cvt_dbaddr, /* cvt_dbaddr */
+ get_array_info, /* get_array_info */
+ put_array_info, /* put_array_info */
+ get_units, /* get_units */
get_precision, /* get_precision */
- NULL, /* get_enum_str */
- NULL, /* get_enum_strs */
- NULL, /* put_enum_str */
- NULL, /* get_graphic_double */
- NULL, /* get_control_double */
- NULL /* get_alarm_double */
+ get_enum_str, /* get_enum_str */
+ get_enum_strs, /* get_enum_strs */
+ put_enum_str, /* put_enum_str */
+ get_graphic_double, /* get_graphic_double */
+ get_control_double, /* get_control_double */
+ get_alarm_double /* get_alarm_double */
epicsExportAddress(rset,seqRSET);
@@ -406,15 +420,91 @@
* Return the precision value from PREC
+#define indexof(field) seqRecord##field
+#define get_dol(prec, fieldOffset) \
+ &((linkDesc*)&prec->dly1)[fieldOffset>>2].dol
+ seqRecord *prec = (seqRecord *) paddr->precord;
+ int fieldOffset = dbGetFieldIndex(paddr) - indexof(DLY1);
+ if (fieldOffset >= 0) switch (fieldOffset & 2) {
+ case 0: /* DLYn */
+ break;
+ case 2: /* DOn */
+ dbGetUnits(get_dol(prec, fieldOffset),
+ units, DB_UNITS_SIZE);
+ return(0);
+ short precision;
+ *pprecision = 2;
+ return 0;
+ case 2: /* DOn */
+ if (dbGetPrecision(get_dol(prec, fieldOffset),
+ &precision) == 0) {
+ return 0;
- if(paddr->pfield < (void *)&prec->val)
- return 0; /* Field is NOT in dbCommon */
- recGblGetPrec(paddr, pprecision); /* Field is in dbCommon */
- return 0;
+ return 0;
+ pgd->lower_disp_limit = 10.0;
+ return 0;
+ case 2: /* DOn */
+ dbGetGraphicLimits(get_dol(prec, fieldOffset),
+ return 0;
+ return 0;
+ if (fieldOffset >= 0 && (fieldOffset & 2) == 0) /* DLYn */
+ return(0);
+ if (fieldOffset >= 0 && (fieldOffset & 2) == 2) /* DOn */
+ dbGetAlarmLimits(get_dol(prec, fieldOffset),
+ else
+ return 0;
=== modified file 'src/rec/subArrayRecord.c'
--- src/rec/subArrayRecord.c 2009-04-23 22:19:46 +0000
+++ src/rec/subArrayRecord.c 2010-05-27 15:14:24 +0000
@@ -201,25 +201,30 @@
return 0;
+#define indexof(field) subArrayRecord##field
subArrayRecord *prec = (subArrayRecord *) paddr->precord;
+ break;
return 0;
- if (fieldIndex != subArrayRecordVAL)
return 0;
@@ -228,25 +233,29 @@
- case subArrayRecordVAL:
- break;
- case subArrayRecordINDX:
- pgd->upper_disp_limit = prec->malm - 1;
- pgd->lower_disp_limit = 0;
- break;
- case subArrayRecordNELM:
- pgd->upper_disp_limit = prec->malm;
- pgd->lower_disp_limit = 1;
- break;
- default:
+ break;
+ case indexof(INDX):
+ pgd->upper_disp_limit = prec->malm - 1;
+ break;
+ case indexof(NELM):
+ pgd->upper_disp_limit = prec->malm;
+ break;
+ break;
+ case indexof(BUSY):
+ pgd->upper_disp_limit = 1;
+ break;
+ default:
return 0;
@@ -255,25 +264,29 @@
- break;
- pcd->upper_ctrl_limit = prec->malm - 1;
- pcd->lower_ctrl_limit = 0;
- break;
- pcd->upper_ctrl_limit = prec->malm;
- pcd->lower_ctrl_limit = 1;
- break;
- default:
+ break;
+ pcd->upper_ctrl_limit = prec->malm - 1;
+ break;
+ pcd->upper_ctrl_limit = prec->malm;
+ pcd->lower_ctrl_limit = 1;
+ break;
+ break;
+ pcd->upper_ctrl_limit = 1;
+ break;
+ default:
return 0;
=== modified file 'src/rec/subRecord.c'
--- src/rec/subRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/subRecord.c 2010-05-27 15:14:24 +0000
@@ -191,54 +191,79 @@
return S_db_BadSub;
+#define indexof(field) subRecord##field
+ return -1;
subRecord *prec = (subRecord *)paddr->precord;
+ int linkNumber;
+ else
return 0;
- if (fieldIndex != subRecordVAL)
+ int linkNumber;
+ return 0;
+ short precision;
+ else
+ *pprecision = 15;
+ } else
return 0;
+ int linkNumber;
- case subRecordVAL:
- case subRecordHIHI: case subRecordHIGH:
- case subRecordLOW: case subRecordLOLO:
- case subRecordA: case subRecordB:
- case subRecordC: case subRecordD:
- case subRecordE: case subRecordF:
- case subRecordG: case subRecordH:
- case subRecordI: case subRecordJ:
- case subRecordK: case subRecordL:
- case subRecordLA: case subRecordLB:
- case subRecordLC: case subRecordLD:
- case subRecordLE: case subRecordLF:
- case subRecordLG: case subRecordLH:
- case subRecordLI: case subRecordLJ:
- case subRecordLK: case subRecordLL:
- break;
- default:
+ break;
+ default:
+ } else
return 0;
@@ -246,24 +271,21 @@
- switch (fieldIndex) {
- break;
- default:
+ break;
+ default:
return 0;
@@ -272,6 +294,7 @@
+ int linkNumber;
if (fieldIndex == subRecordVAL) {
@@ -279,7 +302,15 @@
} else {
+ } else
return 0;
=== modified file 'src/rec/waveformRecord.c'
--- src/rec/waveformRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/waveformRecord.c 2010-05-27 15:14:24 +0000
@@ -194,25 +194,30 @@
return 0;
+#define indexof(field) waveformRecord##field
waveformRecord *prec = (waveformRecord *) paddr->precord;
+ break;
return 0;
- if (fieldIndex != waveformRecordVAL)
return 0;
@@ -220,11 +225,22 @@
- if (dbGetFieldIndex(paddr) == waveformRecordVAL) {
- } else
+ break;
+ break;
+ break;
+ default:
return 0;
@@ -232,11 +248,22 @@
- } else
+ break;
+ break;
+ break;
+ default:
return 0;
Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Ralph Lange
[Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
<2010>
Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Re: [Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base Dirk Zimoch
<2010>
