I just learned that the recently introduced VAL keyword does not
(quoting the Record Reference Manual) return "the current contents of
the VAL field" but rather "the current contents of this expression's
result".
Which means, that inside a calcout record's OCAL expression, VAL refers
to OVAL, not VAL.
Which means you can not use VAL inside OCAL to refer to the result of
the CALC expression, but have to repeat the CALC expression inside OCAL
to get the same value.
Which (in my case) makes the OCAL expression more than 40 characters
long, which doesn't work.
Should we change the behaviour or the documentation?
Ralph
- Re: VAL keyword in calcout records Andrew Johnson
RE: missing monitors Davidsaver, Michael
<2010>
RE: naming the operating system independence layer Jeff Hill
<2010>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
