2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: FW: StreamDevice bug
To: <[email protected]>
Cc: [email protected], [email protected]
Date: Mon, 15 Feb 2010 16:53:56 -0000
In a recent exchange between Dirk and us about streamDevice, Dirk
pointed out one way in which stringout is different to other base output
records - it won't call device support if UDF is true.
Is this deliberate or a bug? If it is a bug, should we fix it because it
will result in a behaviour change?
I can see a viable argument that the opposite should be true - device
support shouldn't be called if UDF is true. A third alternative is that
the  decision should be deferred to device support.
I know stringout is different to other standard output records because
constant links can't be strings, because strings resolve as db or CA
links. The workaround is to put the string into VAL and make OMSL
supervisory. This should actually solve our problem (because UDF won't
be true anymore), but I was wondering whether there was any reasoning
behind the current implementation.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
-----Original Message-----
Sent: 02 February 2010 08:29
To: Cobb, Tom (DLSLtd,RAL,DIA)
Cc: Pratt, Linda (DLSLtd,RAL,DIA); Rees, Nick (DLSLtd,RAL,DIA)
Subject: Re: StreamDevice bug
Hi Tom,
You found a bug in the stringout record (not in stream device). The
stringout record does not process its output link as long as it is UDF.
Once you wrote to the VAL field it works. Setting DOL to a *numeric*
value solves the problem.
The relevant code is here: (src/rec/stringoutRecord.c)
static long process(pstringout)
	struct stringoutRecord	*pstringout;
         if(pstringout->udf == TRUE ){
                 recGblSetSevr(pstringout,UDF_ALARM,INVALID_ALARM);
                 goto finish;
         if (pstringout->nsev < INVALID_ALARM )
                 status=writeValue(pstringout); /* write the new value
         else {
No other record has such "if(pstringout->udf == TRUE )" code.
Best regards,
Dirk
[email protected] wrote:
> Hi,
> We've been doing some testing of our modules, and uncovered a minor
bug
> in streamDevice, I wonder if you've seen it before?
> Symptoms:
> Processing a stringout record that runs a function without a format
> convertor has no effect. Ao, bo and longout records all work fine.
> Example:
> Database:
> record(ao, "TESTSTREAM:ao")
>     field(DTYP, "stream")
>     field(OUT,  "@test.proto reseed streamDeviceAsyn")
> record(bo, "TESTSTREAM:bo")
> record(longout, "TESTSTREAM:longout")
> record(stringout, "TESTSTREAM:stringout")
> Protocol file:
> reseed { out "SYSTEM:RESEED" ; }
> Test:
> Sniffing the serial line reveals that a "caput TESTSTREAM:ao.PROC 1"
> sends "SYSTEM:RESEED", but a "caput TESTSTREAM:stringout.PROC 1" sends
> nothing.
> Any ideas?
> Thanks,
> Tom Cobb,
> Diamond Light Source Ltd.
> Diamond House
> Harwell Science and Innovation Campus
> Didcot
> Oxfordshire
> OX11 0DE
> Tel +44 (0) 1235 778582
Re: FW: StreamDevice bug Andrew Johnson
Prev: devLibPCI prototype Davidsaver, Michael
Next: Re: FW: StreamDevice bug Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
