g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: Channel Access Client Interface
To: <core-talk@aps.anl.gov>
Date: Mon, 8 Aug 2005 12:01:52 -0700
My understanding is that we are stuck at this place:
One position:
We support all data types native to the machine on which the client is run. The ADO handles all conversions, gives native type for each channel connected, gives sizeof infromation for allocating storage, and returns the value in that type of variable - where the space is provided by the user.
The other position:
We support a limited number of types that support all of the data that we need to support. The server puts the data into one of these limited set. Otherwise, it is the same as above.
The difference in the two, is that the ADO handles many different types in the first position and in the second position the server has to put data into one of the limited set and the ADO only handles the limited set.
Is this right?
In the first place - the ADO is big and handles a lot. In the second place, it is small and does not support everything.
Our clients will be about 70% JAVA, and 30% C. How much work is required to get the functionality in the first option into all of these platforms? How much is it in the second options?
Where is the example codes that implement the various client functions with the proposed libraries?
Where is the protocol that was going to be placed on the wiki?
Bob
Re: Channel Access Client Interface Kay-Uwe Kasemir
RE: Channel Access Client Interface Jeff Hill
Prev: core meeting / presentation during EPICS meeting Matthias Clausen
Next: Re: Channel Access Client Interface Kay-Uwe Kasemir
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
