g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: V4 design issue: Should primitive data types have well defined precisions?
From: Benjamin Franksen <benjamin.franksen@bessy.de>
To: core-talk@aps.anl.gov
Date: Wed, 22 Jun 2005 15:23:06 +0200
On Wednesday 22 June 2005 14:47, Dalesio, Leo `Bob` wrote:
> >From a functional point of view - the DA approach gives you total
> > flexibility.
> What does it do to the complexity of the implementation and the
> performance? Does it have an impact on the server? Or just the client
> side?
It depends. The more primitive types your language supports, the less
work the DA-CA-bridge has to do converting.
For instance, a native Java server would have to convert requests for
unsigned types on the server side. A Perl client will probably have to
do a lot of work in order to convert Perl scalar values to whatever is
appropriate, taking the server's native type into consideration.
Similar for most untyped or dynamically types languages.
OTOH, IOCs are probably /not/ going to be implemented in Java. Or Perl
or Haskell ;-)). And /if/ they are, we will have more severe problems
with efficiency than those caused by network-native type conversion!
A C/C++ server need not convert primitive types. Regarding complex
(composite) types, I suggest interfaces should be designed to allow
efficient implementation in C/C++, as has been the goal with the
current DA proposal, IIRC.
Ben
RE: V4 design issue: Should primitive data types have well defined precisions? Dalesio, Leo `Bob`
Prev: Re: V4 design issue: Should primitive data types have well defined precisions? Ralph Lange
Next: Re: V4 design issue: Should primitive data types have well defined precisions? Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Next: EPICS V4: Record Processing Benjamin Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
